OK, got a question about coaxial cable.
Jstas
Jstas Posts: 14,997
Most cable companies use RG-6 coax cable. I have, sitting around, some lengths of RG-59 coax cable. It's free so I was wondering what the differences would be. I need some longer lengths of cable at home and if this RG-59 will work in place of RG-6 I'll use it.
So far, all I can tell is that RG-6 is 75 ohms, max voltage is 2700 and it's about .35 inches thick. RG-59 is also 75 ohms but max voltage is only 2300 and it's size is about .242 inches. Otherwise, they seem very similar.
Any ideas?
Expert Moron Extraordinaire
Post edited by Jstas on
  • bknauss
    bknauss Posts: 1,441
    edited February 2005
    I know there's some issues with satellites and RG-59, but not with RG-6. My thought is there is an issue with bandwidth on the RG-59... but I could be completely wrong.
    Brian Knauss
    ex-Electrical Engineer for Polk
  • Frank Z
    Frank Z Posts: 5,860
    RG-6 is for satelllite systems, RG-59for catv and OTA antennas.
  • Jstas
    Jstas Posts: 14,997
    So I couldn't use RG-59 for wall to TV cable hookup? It's just basic cable. No satellite, no broadband.
  • Frank Z
    Yes you can, shoulda clarified. RG6 will work for DBS, CATV & OTA Antennas, RG-59 for CATV & OTA Antennas
  • wlrandall
    wlrandall Posts: 440
    Originally posted by Frank Z
    RG-59 is for satelllite systems, RG-6 for catv and OTA antennas.
    Actually, the opposite is true. RG-59 cannot transmit the higher frequencies required for satellite, use RG6.
  • Frank Z
    D'oh!!!!!!!
    You are absolutely correct....gotta get my edit on!!
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    If I remember right RG-59 has higher loss over RG-6, so I think (have before used) RG-6 can be used for everything, OTA and or Satellite.
    I would use the RG-59 for some RF patch cables only, using RG-6 for any runs in the house.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • HBombToo
    HBombToo Posts: 5,256
    D'oh!!!!!!!
    Love ya Frank... you make me laugh***:D ***
    IMHO as an engineer it is... gulp:p... the 6 series is more rigid than the 59 and holds its 75 Ohm characteristic longer but is a pain to work with. Its heavey stuff and if not ran correctly could damage the connectors on the electrics.
    1/4twin
    the Alcoholic, Abusing Coors Light drinker
    ***WAREMTAE***
  • dorokusai
    dorokusai Posts: 25,576
    RG-6. Why was there ever a doubt? Oh, nevermind.
  • Jstas
    Jstas Posts: 14,997
    I don't think anyone doubted anything. All I asked was in RG-59 was good for cable TV use 'cause it looks very similar to RG-6 with similar attributes.
  • disneyjoe7
    Just my input.
    Never install RG-59 in walls / attic / or whatever, it's cheaper by what $.10 a foot. I seen many RG-59 installations pulled out reran RG-6 cable so install it right the first time.
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • dorokusai
    John - It wasn't meant in a particular way, just knowing what I know....I thought at this point, this type of coaxial was a given by now. Sorry.
  • PolkThug
    PolkThug Posts: 7,532
    I'm running RG59 inside to my HDTV. Are you guys saying the R6 will give a better picture? Anybody make the switch and really see a difference?
    If it will make the picture look better I'm all for rewiring it, but I don't want to waste my time if you know what I mean.
    Doh! One more thing to obsess over.:)
  • unc2701
    unc2701 Posts: 3,587
    depends on your length of run, too.... If in doubt use rg-6, but if it won't be a pain to replace later, might as well try the rg-59. I had a mess of rg-59 wasting space, so I tried some fairly long runs on digital cable, HDTV, cable modem & satellite and it worked great- but I wasn't going past any flourescent lights, power lines, etc.
    Backburner:Krell KAV-300i
  • Jstas
    Jstas Posts: 14,997
    Originally posted by disneyjoe7
    Just my input.
    The RG-59 I have is FREE so it's considerably cheaper per foot.
  • dorokusai
    LOL
