OK, got a question about coaxial cable.
Jstas
Most cable companies use RG-6 coax cable. I have, sitting around, some lengths of RG-59 coax cable. It's free so I was wondering what the differences would be. I need some longer lengths of cable at home and if this RG-59 will work in place of RG-6 I'll use it.
So far, all I can tell is that RG-6 is 75 ohms, max voltage is 2700 and it's about .35 inches thick. RG-59 is also 75 ohms but max voltage is only 2300 and it's size is about .242 inches. Otherwise, they seem very similar.
Any ideas?
Any ideas?
Expert Moron Extraordinaire
Post edited by Jstas on
I know there's some issues with satellites and RG-59, but not with RG-6. My thought is there is an issue with bandwidth on the RG-59... but I could be completely wrong.Brian Knauss
ex-Electrical Engineer for Polk -
RG-6 is for satelllite systems, RG-59for catv and OTA antennas.
So I couldn't use RG-59 for wall to TV cable hookup? It's just basic cable. No satellite, no broadband.Expert Moron Extraordinaire
Yes you can, shoulda clarified. RG6 will work for DBS, CATV & OTA Antennas, RG-59 for CATV & OTA Antennas
Originally posted by Frank Z
RG-59 is for satelllite systems, RG-6 for catv and OTA antennas.
Actually, the opposite is true. RG-59 cannot transmit the higher frequencies required for satellite, use RG6. -
D'oh!!!!!!!
You are absolutely correct....gotta get my edit on!! -
If I remember right RG-59 has higher loss over RG-6, so I think (have before used) RG-6 can be used for everything, OTA and or Satellite.
I would use the RG-59 for some RF patch cables only, using RG-6 for any runs in the house.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
D'oh!!!!!!!
Love ya Frank... you make me laugh***:D ***
IMHO as an engineer it is... gulp:p... the 6 series is more rigid than the 59 and holds its 75 Ohm characteristic longer but is a pain to work with. Its heavey stuff and if not ran correctly could damage the connectors on the electrics.
1/4twin
the Alcoholic, Abusing Coors Light drinker
***WAREMTAE*** -
RG-6. Why was there ever a doubt? Oh, nevermind.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
I don't think anyone doubted anything. All I asked was in RG-59 was good for cable TV use 'cause it looks very similar to RG-6 with similar attributes.Expert Moron Extraordinaire
Just my input.
Never install RG-59 in walls / attic / or whatever, it's cheaper by what $.10 a foot. I seen many RG-59 installations pulled out reran RG-6 cable so install it right the first time.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
John - It wasn't meant in a particular way, just knowing what I know....I thought at this point, this type of coaxial was a given by now. Sorry.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint. -
I'm running RG59 inside to my HDTV. Are you guys saying the R6 will give a better picture? Anybody make the switch and really see a difference?
If it will make the picture look better I'm all for rewiring it, but I don't want to waste my time if you know what I mean.
Doh! One more thing to obsess over.:) -
depends on your length of run, too.... If in doubt use rg-6, but if it won't be a pain to replace later, might as well try the rg-59. I had a mess of rg-59 wasting space, so I tried some fairly long runs on digital cable, HDTV, cable modem & satellite and it worked great- but I wasn't going past any flourescent lights, power lines, etc.Gallo Ref 3.1 : Bryston 4b SST : Musical fidelity CD Pre : VPI HW-19
Backburner:Krell KAV-300i -
Originally posted by disneyjoe7
Just my input.
The RG-59 I have is FREE so it's considerably cheaper per foot.Expert Moron Extraordinaire
LOLCTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
