Cheap garage AVR that sounds decent?
afterburnt
in Electronics
It's actually for my shed. Need wifi so I can stream from my NAS. Needs to be cheap like a couple few hundred. If you kind folks could point me in the right direction I would be much obliged.
I just sent for a YAMAHA RX-V485 my Yamaha R-N303 goes in the shed.
Yamaha ain't done me wrong so far.
Why an AVR and not two-channel?
I mean, depending upon one's "definition" of "AVR" there are great bargains out there -- you know, this stuff is obsolete after 18 months, so the resale value plummets essentially in real time. Gotta love the relentless march of technology
Even as I type this, I am listenin' to the news on this "5.1" era monstrosity.
Found it in the electronics scrap at our daughter & son-in-law's town dump. Someone paid $10 to get rid of it. Well built. Worked fine as found (needed to have controls cleaned).
DSC_7313 by Mark Hardy, on Flickr
DSC_7543 (2) by Mark Hardy, on Flickr
I have an N303 in my garage and it is fine... I'll let you know how it survived a Florida Garage summer in November...
My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
@mhardy6647 AVR for the flexibility I guess.
@Mikey081057 I am pretty sure I will keep the AVR in the house and send the N303 to the woodshed. -
afterburnt wrote: »@mhardy6647 AVR for the flexibility I guess.
Discuss.
Speakers?
Inputs?
signal processing?
sheer number of innies and outties on the back?
my brain pops right on out my head and scurries around on the floor like a newt when I see stuffs like that.
Couldn't you use any old receiver or AVR with out WiFi, connected to a cheap DLNA compatible Blu-ray player like a Sony BDP-S580?HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Rt35i Surrounds/Cs1000p Center/SVS BP1000 Sub
2CH - B&K MC-101 pre/B&K EX-442 amp/NAD 2400 amp
Polk SDA1C, Polk Monitor 7, New Large Advents and Polk RTA 8T
BR - Yamaha CR800/Polk monitor 5 -
Easy Runnin wrote: »Couldn't you use any old receiver or AVR with out WiFi, connected to a cheap DLNA compatible Blu-ray player like a Sony BDP-S580?
or a chromecast, or a Squeezebox, or a Roku, etc. etc....Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Better yet any old receiver & a chromecast audio will get the job done.
Wouldn’t those option require an HDMI input source on the receiver?HT- Samsung PN50B860/Integra DTR 30.3/Rt55 Fronts
Chrome cast audio has a dual purpose 1/8" analog/optical out.
Roku will stream from my NAS? I got a Roku stick around here somewhere.
afterburnt wrote: »Easy Runnin wrote: »Couldn't you use any old receiver or AVR with out WiFi, connected to a cheap DLNA compatible Blu-ray player like a Sony BDP-S580?
With plex it will...and all you need is the free app.Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
Cool! I should have just asked you in the first place. -
afterburnt wrote: »afterburnt wrote: »Easy Runnin wrote: »Couldn't you use any old receiver or AVR with out WiFi, connected to a cheap DLNA compatible Blu-ray player like a Sony BDP-S580?
You do have to put plex on your puter and the stick FYI...I’m not sure how to connect directly to a NAS but there are folks here that do!Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
My Synology NAS came with Plex server as an available add in. All I had to do was get into the NAS GUI and install it. Then install the Plex client software on devices where I want to listen to tunes. Everything talks to each other through your home network. I can also listen to my entire music collection away from home on my iPhone using cellular data service. Then Blue Tooth it to some better speaks. Plex is kinda cool. -
My shop yammie sits near my TV so I stream Amazon Music HD to it via toslink.
Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
I am running mine with those same speakers 6's no? What Yamaha is that? -
Those are the 5's. Yamaha HTR-5540. I think I got it for $20 bucks about 7 years ago.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2
