Trouble hooking signa S2 to TV that runs on firestick.
KB1
i purchased a signa S2 sound bar, trying to hook to a TV that does not have HDMI ARC or an optical outlet port. we use a Firestick to watch TV, my TV does have a digital audio out but it is RCA (coaxial). What is the correct way to connect sound bar? i have tried several different options, none of them has worked.
Best Answer
Usually a digital output that is not HDMI uses a Toslink cable rather than an RCA cable. Try using a cable that has RCA on one end and a 3.5mm plug on the other end connected into the corresponding 3.5mm input on the soundbar.
Answers
Thank you for the response, I will give that try.
You're welcome!
