Aerial Acoustics 10T MKii
Gerres26
Gerres26 Posts: 874
edited August 2020 in For Sale (FS) Classifieds
On an attempt to move another pair of TOTL vintage loudspeakers, here is a pair of my Aerial Acoustics 10T MKii. I’m asking $2100 on here for a Polkie discount. They are priced higher on USaudiomart currently. As with the 1.2tls, I may entertain trades for a like valued high power amplifier.
I do have the boxes/packaging for these guys but would prefer local pickup. I am located in Maryland 21921. Shipping may work if someone is willing to totally set it up as I have never shipped anything freight before although I am more than capable of strapping these guys to a pallet if that is needed.
Being a MKII, these have upgraded crossovers and the improved Novalith cast synthetic stone head material for the tweeter/midrange module, which does not have the hair-line cracking problem of the MKI experienced. The swiveling heads are in very nice condition with minimal scuffs as pictured. The bass cabinets are finished in the highly desirable Rosewood veneer finish. Each speaker has a cosmetic repair to the veneer on one bottom corner. One is barely noticeable, and both are cosmetic only. This pair also comes with custom made stands, which are mounted on heavy duty furniture grade casters, which really help with positioning these speakers. They are bi-ampable, and come with top quality drivers.
Specs:
Description: Three-way, floor standing, dynamic loudspeaker with reflex-loaded bass cabinet and separate tweeter/midrange module. Drive-units: 1" titanium-dome tweeter, 5.3" (136mm) dual Kevlar/epoxy-laminated-cone midrange unit, and 10.7" (271mm) bilaminate composite-cone woofer. Crossover frequencies: 360Hz, 2.7kHz. Crossover slopes: fourth-order, 24dB/octave, acoustic Linkwitz-Riley. Frequency response: 28Hz-20kHz, -2dB, -6dB at 23 Hz. Sensitivity: 86dB/W/m (2.83V). Nominal impedance: 4 ohms, 3 ohms minimum. Amplifier requirements: 50W minimum, >100W recommended.
Dimensions: 41.5" H by 13.75" W by 19" D. Shipping weight: 190 lbs (shipped in three boxes).
https://www.stereophile.com/floorloudspeakers/466/index.html
Pics to follow
