D5000.5 - Turn on Noise / Squeal / Hiss
emjohn43
Hello:
Have a D5000.5 amp I bought new in January 2020. From day 1, the amp has made a noise for a few seconds when powered up, but after the amp gets a signal from the HU, the noise stops.
I have tried:
Removing the RCA inputs, one by one, until all removed - noise still present.
Jumping the remote wire to the power wire, to turn on the amp without anything of the car on - noise is still present.
Disconnecting one by one each speaker output - noise is still present.
The ground wire is 4awg, and right to the frame, at a clean, sanded, ground point. The length is approximately 12 inches.
The power wire is 4awg, and right to the battery positive, with a fuse within 12-inches. The length is approximately 12 feet.
Here are two videos, the first is a normal ignition on (no engine start), and the second, is me jumping the power wire to the remote wire. Both videos the sound starts 6 seconds in.
https://youtu.be/obXWAiVEp3g
https://youtu.be/dUz-FFJmVkA
I believe I am now at the conclusion that this is a faulty amplifier. How else should I test to confirm?
I have tried:
https://youtu.be/dUz-FFJmVkAI believe I am now at the conclusion that this is a faulty amplifier. How else should I test to confirm?
Hello,
It sounds like you've done all you could to determine that the amp is at fault. Probably the best place to begin is by contacting Polk at: 1-800-377-7655 and follow the prompts for car audio. Or, you could send it to: Polk Service, One Viper Way, Vista, CA. 92081 include a note with your name, address, email address, telephone number a description of the problem and a copy of your sales receipt. They'll quickly get things straightened out.
