Chroma Color Gamut 4:4:4 vs 4:2:0 (Marantz SR 5011)
My Marantz SR 5011 is only allowing a Chroma rating pass thru of 4:2:0 and only 4K SDR (tested via Apple TV). Probably even better on my Oppo but can't test it.
When I by pass the Marantz and plug the Apple TV directing into the TV I get 4K HDR, 4:2:2. Think I even got 4:4:4 once but forgot to take a pic of it.
I am using a Mediabridge Ultra series HDMI 2.0 (18 Gbps) that supports 4K @ 60Hz.
Questions:
1: Is there a noticeable difference between 4:4:4 & 4:2:0 chroma ratings?
2: Can I alter my Marantz to increase the color space beyond 4:2:0? I tried but could not figure it out.
I'm doing all this because I'm not in love with the picture of my Sony TV. I understand it is a mid tier Sony but other much cheaper TVs in my house look better IMHO.
Thanks in advance for any comments.
AVR: Marantz SR 5011
L/ R: Polk Audio 703 LSiM (Bi Amp'd)
C: Polk Audio 255c - LS
R: Def Tech
Sub: PSW 505 (12 inch)
DVD: Oppo UDP 203
TV: 2016 Sony XBR 75X850D
    msg Posts: 10,452
    Interesting question; watching.
  • Kingkwas
    Kingkwas Posts: 92
    Quick update: I found deep in the tech specs online that the Marantz SR 5011 supports 4:4:4 color spacing...
    Per Crutchfield website:
    "4:4:4 Color Subsampling: All of the receiver's rear-panel HDMI jacks support RGB, YCbCr 4:4:4, YCbCr 4:2:2, and YCbCr 4:2:0 color subsampling (@ 60Hz or 50Hz). With 4:4:4 color subsampling, luminance (brightness) and chroma (color) are sampled at the same rate; resulting in an RGB color palette as big as the video sampling rate for a video image with more colors, plus greater color accuracy and detail. The front-panel HDMI only supports 4K 60/50Hz using format YCbCr 4:2:0 only."
    https://www.crutchfield.com/p_642SR5011/Marantz-SR5011.html#&gid=1&pid=2
    R: Def Tech
    DVD: Oppo UDP 203
  • Kingkwas
    Kingkwas Posts: 92
    Think my problem might lie with my HDMI 2.0 18Gbps cable.
    Where can I find a next gen HDMI 2.1 cable with 48Gbps?
    R: Def Tech
    DVD: Oppo UDP 203
  • machone
    machone Posts: 1,559
    I checked this a few weeks ago and my understanding is there is no such thing yet available. There are some claims but I cannot find a cable with a logo specified by HDMI.org If you go to HDMI.org it may help.
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
    pitdogg2 Posts: 27,047
    edited August 2020
    . Where can I find a next gen HDMI 2.1 cable with 48Gbps?
    Most Audioquest's cables will pass above and beyond the current specs
  • joecoulson
    joecoulson Posts: 4,943
    I would surmise you would need a high end OLED or the like to gain that full spectrum
