Chroma Color Gamut 4:4:4 vs 4:2:0 (Marantz SR 5011)
Kingkwas
in Electronics
My Marantz SR 5011 is only allowing a Chroma rating pass thru of 4:2:0 and only 4K SDR (tested via Apple TV). Probably even better on my Oppo but can't test it.
When I by pass the Marantz and plug the Apple TV directing into the TV I get 4K HDR, 4:2:2. Think I even got 4:4:4 once but forgot to take a pic of it.
I am using a Mediabridge Ultra series HDMI 2.0 (18 Gbps) that supports 4K @ 60Hz.
Questions:
1: Is there a noticeable difference between 4:4:4 & 4:2:0 chroma ratings?
2: Can I alter my Marantz to increase the color space beyond 4:2:0? I tried but could not figure it out.
I'm doing all this because I'm not in love with the picture of my Sony TV. I understand it is a mid tier Sony but other much cheaper TVs in my house look better IMHO.
Thanks in advance for any comments.
Questions:
AVR: Marantz SR 5011
L/ R: Polk Audio 703 LSiM (Bi Amp'd)
C: Polk Audio 255c - LS
R: Def Tech
Sub: PSW 505 (12 inch)
DVD: Oppo UDP 203
TV: 2016 Sony XBR 75X850D
R: Def Tech
DVD: Oppo UDP 203
Quick update: I found deep in the tech specs online that the Marantz SR 5011 supports 4:4:4 color spacing...
Per Crutchfield website:
"4:4:4 Color Subsampling: All of the receiver's rear-panel HDMI jacks support RGB, YCbCr 4:4:4, YCbCr 4:2:2, and YCbCr 4:2:0 color subsampling (@ 60Hz or 50Hz). With 4:4:4 color subsampling, luminance (brightness) and chroma (color) are sampled at the same rate; resulting in an RGB color palette as big as the video sampling rate for a video image with more colors, plus greater color accuracy and detail. The front-panel HDMI only supports 4K 60/50Hz using format YCbCr 4:2:0 only."
https://www.crutchfield.com/p_642SR5011/Marantz-SR5011.html#&gid=1&pid=2AVR: Marantz SR 5011
R: Def Tech
DVD: Oppo UDP 203
TV: 2016 Sony XBR 75X850D -
Think my problem might lie with my HDMI 2.0 18Gbps cable.
Where can I find a next gen HDMI 2.1 cable with 48Gbps?AVR: Marantz SR 5011
R: Def Tech
DVD: Oppo UDP 203
I checked this a few weeks ago and my understanding is there is no such thing yet available. There are some claims but I cannot find a cable with a logo specified by HDMI.org If you go to HDMI.org it may help.Mojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
"All THAT IS LOST FROM THE SOURCE IS LOST FOREVER" -
I would surmise you would need a high end OLED or the like to gain that full spectrum
