Power Cord recommendation
pearsall001
Looking for 2 - 5' cords. One for the preamp (Rogue Audio RP-1) & power amp (Parasound ZM 2350). Budget of $250.00 max.per PC.
I would prefer new but would not rule out going used. I've looked at Cullen Cable, MAZE Audio, Signal cable, Shunyata just to name a few.
Nice to see you man! Hope all is well!"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963)
EndersShadow wrote: »Nice to see you man! Hope all is well!
All is well, hopefully the same with you.
I've been quiet for awhile with other things on my plate.
I just picked up a few new pieces of gear & am getting back into the swing of things."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up. -
I like the PS Audio PC I have. It's well built and very flexible for it's size.afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
I'll check them out. Thanks 👍"2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up. -
VH Audio "Flavor 4". It's a noise rejecting, star quad, counter-spiraled ground design. The DIY version with Furutech connectors are in your price range and are excellent cables. You might also look at Ice Age Audio for budget minded cryoed cables.
I like the PS one I have too. (Ac-12)
If I could muster, I would have AQ Thunders on all. Oh well.
I do have an AQ monsoon that’s nice. Used would fit your budget for that.
So would a used PS A ac5 -
For the cash, the Cullen are really good.Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
I gave Frank at Signal Cable a shout out for his Magic Power Cord for the Rogue pre. I never tried one of his PC's before. It's worth a shot I figured. If I like it I can always add another for the amp. If not I'll move on & give another companies PC a try."2 Channel & 11.2 HT "Two Channel:Magnepan LRSSchiit Audio Freya S - SS preConsonance Ref 50 - Tube preParasound HALO A21+ 2 channel ampBluesound NODE 2i streameriFi NEO iDSD DAC Oppo BDP-93KEF KC62 sub Home Theater:Full blown 11.2 set up.
