need quick help
dtownshoots
dtownshoots Posts: 5
edited February 2005 in Car Subwoofer Talk
i already bought my 1000w crunch amp, got the wiring, and will buy the box for my sub(s).
The sub is an audiobahn aw102T - 450rms and 900 peak
should i get another sub or will this one work fine? also am i risking blowing out the sub with the 1000 w power?
1994 Ford Explorer
- Kenwood - Headunit
- 6x8 Rockford Fosgates - Front
- 6x9 Bazooka - Rear
- 1000w Crunch - Amp
- 10" Audiobahn 450rms - Subwoofer
Post edited by dtownshoots on
  • dtownshoots
    edited January 2005
    the amp is:
    Crunch PZN-2250
    250 x 2 @ 4ohms
    500 x 2 @ 2ohms
    just trying to give more info
    1994 Ford Explorer
  • exalted512
    exalted512 Posts: 10,734
    you should be able to bridge that amp to get 500 watts, thats what i would do...
    -Cody
  • PoweredByDodge
    PoweredByDodge Posts: 4,185
    the amp is 1000 x 1 bridged @ 4 ohms.
    but it is most likely very over rated.
    so no - you're not going to hurt the sub.
    The Artist formerly known as PoweredByDodge
  • dtownshoots
    i will probly bridge the 4ohm sub to get 500 watts
    problem solved
    1994 Ford Explorer
