Insane gas bill
BlueFox
BlueFox Posts: 15,250
Being retired I am trying to live on my monthly Social Security check, and not touch my savings. This has been fine for the last 18 months or so. Since I have solar, the biggest part of my monthly utility bill is for gas, and, being summer, that is never much, around $20 a month. So today I get the July bill, and it is $10,000 for gas. Yikes! After calling, and being on hold for an hour, the rep agreed with me that $10K is a bit high for a month. Now I have to wait 2-3 weeks for a new bill. Hopefully it will be back to normal.
  • polrbehr
    polrbehr Posts: 2,857
    edited July 2020
    Just pay it. They need the money a lot more than you do.... ;)
    VR3 Posts: 29,626
    you must have a massive leak
    F1nut Posts: 52,141
    I heard you were a bit gassy.
  • BlueFox
    VR3 wrote: »
    That was my first thought. However, something is added to the gas to make it easy to smell, and it is odor free. I guess I should try using a match for leak detection. :)
  • Joey_V
    Joey_V Posts: 8,603
    :o
  • BlueFox
    I did have a bit of anxiety when I first saw this. :)
  • ptrooper
    ptrooper Posts: 501
    edited July 2020
    double :o:o Wow, that sort of leak would definitely have a good smell around your home and if trapped in a confined area with the correct mixture of air and an ignition source ,would definately cause complete combustion . :#
    Sounds like a Faulty meter ?
    Soapy water and a spray bottles is good for locating leaks!
    I do hope you don't have to pay that one.
    Having a local or friend that is a plumber/gasfitter could test your system!
    Post edited by ptrooper on
  • motorhead43026
    motorhead43026 Posts: 4,048
    I say your solar pays off, big time.
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    Bud I'm pretty sure that bill is correct and you should pay it.
    After all, the folks at PG&E are experts, not to be questioned.
  • Emlyn
    Emlyn Posts: 4,865
    Computer system error. There’s no dollar sign in front of the current gas charge.
  • vmaxer
    vmaxer Posts: 5,121
    Been doing a lot of cooking??😳
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • ptrooper
    ptrooper Posts: 501
    edited July 2020
    Things like this worry me as we have given full authorisation for automatic draw downs on all our bills to date ! There is this slight concern with going paperless.
  • BlueFox
    That is a good point. PG&E is constantly pestering me to setup automatic payments. I always decline since an online payment is so easy.
  • rooftop59
    rooftop59 Posts: 8,120
    BlueFox wrote: »
    I do auto for almost all bills. They send you the amount BEFORE the draft. You can always stop it if something’s amiss...and since it’s a credit card I could do a charge back for a clearly asinine charge like that...
    Game Room 5.1.4:
    Bedroom 2.1
  • Willow
    Willow Posts: 11,305
    We warned you not to start cooking crack!
    nooshinjohn Posts: 26,060
    It might just be a gas charge for all the methane you produce...
  • Mikey081057
    Mikey081057 Posts: 7,127
    Running a meth lab uses a lot of resources...
    Garage | Polk Monitor 5B's
  • sucks2beme
    sucks2beme Posts: 5,694
    Around here- they have had a lot of issues with the new electronic meters.
    I don't think it's the meters so much as they don't document the current reading
    correctly before installing the new on. Almost everyone gets a heart stopping
    bill after the change.
  • BlueFox
    Yes, the person I was talking to was saying the electronic meter hadn’t been working for a while. Now I am waiting for the new, fixed bill.
  • motorhead43026
    edited July 2020
    Smart meters are a big part of my business.
  • lightman1
    lightman1 Posts: 10,797
    I used to install the transceivers.👍
  • BlueFox
    Now I know what happened. :)
  • Mikey081057
    Ir Russ goes out to fix it you'll have 2 gas leaks
