Insane gas bill
BlueFox
BlueFox Posts: 15,251
Being retired I am trying to live on my monthly Social Security check, and not touch my savings. This has been fine for the last 18 months or so. Since I have solar, the biggest part of my monthly utility bill is for gas, and, being summer, that is never much, around $20 a month. So today I get the July bill, and it is $10,000 for gas. Yikes! After calling, and being on hold for an hour, the rep agreed with me that $10K is a bit high for a month. Now I have to wait 2-3 weeks for a new bill. Hopefully it will be back to normal.
  • polrbehr
    polrbehr Posts: 2,826
    edited July 2020
    Just pay it. They need the money a lot more than you do.... ;)
    VR3 Posts: 28,020
    you must have a massive leak
    F1nut Posts: 49,787
    I heard you were a bit gassy.
  • BlueFox
    VR3 wrote: »
    That was my first thought. However, something is added to the gas to make it easy to smell, and it is odor free. I guess I should try using a match for leak detection. :)
  • Joey_V
    Joey_V Posts: 8,518
    :o
    Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
  • BlueFox
    I did have a bit of anxiety when I first saw this. :)
  • ptrooper
    ptrooper Posts: 501
    edited July 2020
    double :o:o Wow, that sort of leak would definitely have a good smell around your home and if trapped in a confined area with the correct mixture of air and an ignition source ,would definately cause complete combustion . :#
    Sounds like a Faulty meter ?
    Soapy water and a spray bottles is good for locating leaks!
    I do hope you don't have to pay that one.
    Having a local or friend that is a plumber/gasfitter could test your system!
    Post edited by ptrooper on
  • motorhead43026
    motorhead43026 Posts: 3,892
    I say your solar pays off, big time.
    2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; LAT International speaker cables, ZU Mission IC's and power cables all into a PS Audio Dectet Power center.
    Other; M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
    The best way to predict the future is to invent it.
    It is imperative that we recognize that an opinion is not a fact.
    Imagine making politics your entire personality.
  • mrbigbluelight
    mrbigbluelight Posts: 9,258
    Bud I'm pretty sure that bill is correct and you should pay it.
    After all, the folks at PG&E are experts, not to be questioned.
  • Emlyn
    Emlyn Posts: 4,367
    Computer system error. There’s no dollar sign in front of the current gas charge.
  • vmaxer
    vmaxer Posts: 5,116
    Been doing a lot of cooking??😳
    Pio Elete Pro 520
    Panamax 5400-EX
    Sunfire TGP 5
    PS Audio GCPH phono pre
    Sunfire CG 200 X 5
    Sunfire CG Sig 405 X 5
    OPPO BDP-83 SE
    Ctr CS1000p
    Sur - FX1000 x 4
    SUB - SVS PB2-Plus
    Workkout room:
    Onkyo TX-DS898
    GFA 555
    Yamaha DVD-S1800BL/SACD
    Ft - SDA 1C
    Not being used:
    RTi 38's -4
    RT55i's - 2
    LSI 15's
    CSi40
    PSW 404
  • ptrooper
    ptrooper Posts: 501
    edited July 2020
    Things like this worry me as we have given full authorisation for automatic draw downs on all our bills to date ! There is this slight concern with going paperless.
  • BlueFox
    That is a good point. PG&E is constantly pestering me to setup automatic payments. I always decline since an online payment is so easy.
  • rooftop59
    rooftop59 Posts: 7,971
    BlueFox wrote: »
    I do auto for almost all bills. They send you the amount BEFORE the draft. You can always stop it if something’s amiss...and since it’s a credit card I could do a charge back for a clearly asinine charge like that...
    Game Room 5.1.4:
    Bedroom 2.1
  • Willow
    Willow Posts: 10,871
    We warned you not to start cooking crack!
    nooshinjohn Posts: 25,093
    It might just be a gas charge for all the methane you produce...
  • Mikey081057
    Mikey081057 Posts: 7,127
    Running a meth lab uses a lot of resources...
    Garage | Polk Monitor 5B's
  • sucks2beme
    sucks2beme Posts: 5,557
    Around here- they have had a lot of issues with the new electronic meters.
    I don't think it's the meters so much as they don't document the current reading
    correctly before installing the new on. Almost everyone gets a heart stopping
    bill after the change.
  • BlueFox
    Yes, the person I was talking to was saying the electronic meter hadn’t been working for a while. Now I am waiting for the new, fixed bill.
  • motorhead43026
    edited July 2020
    Smart meters are a big part of my business.
  • lightman1
    lightman1 Posts: 10,776
    I used to install the transceivers.👍
  • BlueFox
    Now I know what happened. :)
  • Mikey081057
    Ir Russ goes out to fix it you'll have 2 gas leaks
