Insane gas bill
BlueFox
Being retired I am trying to live on my monthly Social Security check, and not touch my savings. This has been fine for the last 18 months or so. Since I have solar, the biggest part of my monthly utility bill is for gas, and, being summer, that is never much, around $20 a month. So today I get the July bill, and it is $10,000 for gas. Yikes! After calling, and being on hold for an hour, the rep agreed with me that $10K is a bit high for a month. Now I have to wait 2-3 weeks for a new bill. Hopefully it will be back to normal.
Just pay it. They need the money a lot more than you do....
http://audiomilitia.proboards.com/ -
you must have a massive leak- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I heard you were a bit gassy.Political Correctness'.........defined
President of Club Polk -
That was my first thought. However, something is added to the gas to make it easy to smell, and it is odor free. I guess I should try using a match for leak detection.
Three 20 amp circuits. -
Magico M2, JL113v2x2, EMM, ARC Ref 10 Line, ARC Ref 10 Phono, VPIx2, Lyra Etna, Airtight Opus1, Boulder, AQ Wel&Wild, SRA Scuttle Rack, BlueSound+LPS, Thorens 124DD+124SPU, Sennheiser, Metaxas R2R -
I did have a bit of anxiety when I first saw this.
double
Wow, that sort of leak would definitely have a good smell around your home and if trapped in a confined area with the correct mixture of air and an ignition source ,would definately cause complete combustion .
Sounds like a Faulty meter ?
Soapy water and a spray bottles is good for locating leaks!
I do hope you don't have to pay that one.
Having a local or friend that is a plumber/gasfitter could test your system!
Post edited by ptrooper on -
I say your solar pays off, big time.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
– Kevin Alfred Strom
Idolizing a politician is like believing the stripper REALLY likes you. -
Bud I'm pretty sure that bill is correct and you should pay it.
After all, the folks at PG&E are experts, not to be questioned.
Sal Palooza -
Just watch it come back at $34,000 more and the customer service chick says “thanks for the call. We were able to fix the software error and here is your proper amount. We accept CC, PayPal, SS, or Magico as forms of payment.”Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!!
Computer system error. There’s no dollar sign in front of the current gas charge.
Been doing a lot of cooking??😳Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Things like this worry me as we have given full authorisation for automatic draw downs on all our bills to date ! There is this slight concern with going paperless.
That is a good point. PG&E is constantly pestering me to setup automatic payments. I always decline since an online payment is so easy.Lumin X1 file player, Westminster Labs interconnect cable
I do auto for almost all bills. They send you the amount BEFORE the draft. You can always stop it if something’s amiss...and since it’s a credit card I could do a charge back for a clearly asinine charge like that...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es
We warned you not to start cooking crack!
It might just be a gas charge for all the methane you produce...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Running a meth lab uses a lot of resources...My New Year's resolution is 3840 × 2160
Garage | Polk Monitor 5B's
Closet Yamaha M80 | 2 Polk MP3K subs| Yaqin MC100B with Shuguang Treasures KT 88's & CV181Z's | Tesla E83CC's | Marantz 2252B | Marantz 2385 |Polk SDA SRS 2.3 | LSiM 705's | -
Around here- they have had a lot of issues with the new electronic meters.
I don't think it's the meters so much as they don't document the current reading
correctly before installing the new on. Almost everyone gets a heart stopping
bill after the change.
"The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
Yes, the person I was talking to was saying the electronic meter hadn’t been working for a while. Now I am waiting for the new, fixed bill.Lumin X1 file player, Westminster Labs interconnect cable
Smart meters are a big part of my business.Since we don’t know where we are going we have to stick together in case someone gets there….Ken Kesey
motorhead43026 wrote: »Smart meters are a big part of my business.
I used to install the transceivers.👍 -
Now I know what happened.
Ir Russ goes out to fix it you'll have 2 gas leaksMy New Year's resolution is 3840 × 2160
