Billet SDA-Neutrik Terminal Plates
xschop
Material is aircraft grade 6061-T6, all CNC machined to accept Neutrik style terminals and any 1/2" diameter binding posts, as well as Cardas brand short posts. Will come loaded with all stainless Neutrik mount screws and stainless 8-32 enclosure mount screws with hurricane nuts for $112 shipped USPS PRIORITY INSURED...US-48 ONLY
PurdyPolitical Correctness'.........defined
President of Club Polk -
Very very nice.
I will take a set of these.
Thanks Outlaw, I will get these out today with the nylon washers as well.
I only have 2 more sets on hand, just PM if interested.
Also I can add two more holes at 11 o'clock and 1 o'clock on request.Don't take experimental gene therapies from known eugenicists. -
All hooked up in my 1.2tl’s. For others Ace Hardware stocks a variety of nylon washers and spacers that make using the heavy duty Dayton terminals work great. I didn’t drill them for Bi-Wiring as I have 8’ 10awg wire feeding them. And I dont plan on Bi-Amping, I can always Add more terminals. Didn’t need to spend extra money on something I wasn’t going to use. Don’t forget get when ordering the neutrix connectors to get the gaskets. I also used rubber splicing tape for the gasket around the ring. Nice and flexible and works awesome.
Sending a set out to WMG. Only one set left for the next few weeks.Don't take experimental gene therapies from known eugenicists.
Scratch that. Looks Like these won't work on SDA-2A terminals.Don't take experimental gene therapies from known eugenicists.
I guess those terminals have crossover components mounted to cups. In reality they are easy to mod as they come apart with a little force as they are spot-glued around perimeter (Monitor ones I've dealt with anyway)
Ok yes that is true. I thought maybe it was in reference to the blade/blade interconnect.
You can match the hole pattern and use threaded rod to mount the boards to the plate- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I actually did a build where the stock cups mounted on the inside of the cut out and the plate on the outside, attached via threaded rod acorn nuts and nuts
- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Good thinking.Don't take experimental gene therapies from known eugenicists. -
I have one last set on hand to offer. It will be another 4-5 weeks before I start another run of these plates. Just PMDon't take experimental gene therapies from known eugenicists.
