Billet SDA-Neutrik Terminal Plates
Material is aircraft grade 6061-T6, all CNC machined to accept Neutrik style terminals and any 1/2" diameter binding posts, as well as Cardas brand short posts. Will come loaded with all stainless Neutrik mount screws and stainless 8-32 enclosure mount screws with hurricane nuts for $112 shipped USPS PRIORITY INSURED...US-48 ONLY
    F1nut Posts: 52,024
    Purdy
    pitdogg2 Posts: 27,372
    Very very nice.
  • Outlaw9
    Outlaw9 Posts: 11
    I will take a set of these.
    xschop Posts: 5,420
    Thanks Outlaw, I will get these out today with the nylon washers as well.
    I only have 2 more sets on hand, just PM if interested.
    Also I can add two more holes at 11 o'clock and 1 o'clock on request.
  • Outlaw9
    Outlaw9 Posts: 11
    edited August 2020
    All hooked up in my 1.2tl’s. For others Ace Hardware stocks a variety of nylon washers and spacers that make using the heavy duty Dayton terminals work great. I didn’t drill them for Bi-Wiring as I have 8’ 10awg wire feeding them. And I dont plan on Bi-Amping, I can always Add more terminals. Didn’t need to spend extra money on something I wasn’t going to use. Don’t forget get when ordering the neutrix connectors to get the gaskets. I also used rubber splicing tape for the gasket around the ring. Nice and flexible and works awesome.
    xschop Posts: 5,420
    Sending a set out to WMG. Only one set left for the next few weeks.
    xschop Posts: 5,420
    Scratch that. Looks Like these won't work on SDA-2A terminals.
    xschop wrote: »
    Why not?
    xschop Posts: 5,420
    I guess those terminals have crossover components mounted to cups. In reality they are easy to mod as they come apart with a little force as they are spot-glued around perimeter (Monitor ones I've dealt with anyway)
    xschop wrote: »
    Ok yes that is true. I thought maybe it was in reference to the blade/blade interconnect.
    VR3 Posts: 29,555
    You can match the hole pattern and use threaded rod to mount the boards to the plate
    VR3 Posts: 29,555
    I actually did a build where the stock cups mounted on the inside of the cut out and the plate on the outside, attached via threaded rod acorn nuts and nuts
    xschop Posts: 5,420
    VR3 wrote: »
    Good thinking.
    xschop Posts: 5,420
    I have one last set on hand to offer. It will be another 4-5 weeks before I start another run of these plates. Just PM
