Marantz NR1504, PM8006, Emotiva XPA 1l
I want to hook up LSiM 703 to the PM8006 and some Monitor 70 to the Emo amps (wineter only they is hot). 1504 pre outs to PM8006 to 703 (A/B?). PM8006 pre outs to Emos to Monitor. Will this work?
  • afterburnt
    afterburnt Posts: 7,892
    Pre outs don't defeat the AB right?
  • afterburnt
    Just making conversation it is pretty dead out here. Dead boring.
  • Nightfall
    Nightfall Posts: 10,083
    My brain hurts.
    I believe, generally, running through two volume pots is frowned upon. I have done it before though to incorporate a 2 channel preamp into a HT setup that didn't have HT bypass and it worked. I ran the center and surrounds off AVR then went AVR front preouts to 2 channel preamp regular input then to B&K amp. Use a db meter app to get the second volume pot equal to the speakers running off the AVR.
    It looks like a mess when you read it in text.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • rooftop59
    rooftop59 Posts: 8,120
    Yes so it looks like the Marantz pm8006 has a power amp direct input which should bypass the volume and allow the avr to control the volume. And no, using the preouts won’t defeat the amp section: otherwise how would you use a sub with it?
    Game Room 5.1.4:
    Bedroom 2.1
