Polk Audio SDA CRS speakers
Can anybody help me with tracking down/acquiring the pin/blade interconnect cables for a pair of 87'-89' 4th generation Polk Audio SDA CRS speakers? Thank you.
Answers
    pitdogg2 Posts: 27,775
    Make one or switch the socket to a speakon type and still make one.
  • boston1450
    boston1450 Posts: 7,758
    Correct me if I'm wrong. I do believe you can run Pin-to-Pin on them. If so you may be able to use a long RCA cable & bend off the out'r blades on the RCA's - so you have just the pin ends... As pitdogg2 speaking is best. I'm using speakon's & love em... Welcome to the forum Dan
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • boston1450
    edited July 2020
    Hope this helps. Here is a old thread on how to make them. There are probably more threads here. https://forum.polkaudio.com/discussion/119305/sda-2-interconnect-cable-need-to-make-one....
    Randy-Maine
    by David WMG
    Yep in a pinch grind off the petals of RCA. I made one with good copper 14ga wire and a set of decent RCA ends.
  • 4dantheman
    boston1450 - thanks for the welcome. With what I read I came to the right place. You mentioned an "old thread" & I went down the rabbit hole. On a post dated Jan 2012, biggrin mentions someone named "pepster (Paul)". Do you or anyone else out there know how I can get ahold of this person to make me an interconnect cable?
    F1nut Posts: 52,301
    Long gone
  • 4dantheman
    Thanks.
