So, you think speaker cables don't matter, think again.
Interesting.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
I like the cubed globe! Noice!
I guess if he had used a shielded cable it would've done the same but that wouldn't address the noise on the line which he didn't test for in this video. Still pretty cool though.George / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
Gardenstater wrote: »I guess if he had used a shielded cable it would've done the same but that wouldn't address the noise on the line which he didn't test for in this video. Still pretty cool though.
Do you know of any speaker cable that is shielded? As for noise on the line, that is power related and is addressed with power conditioning.Political Correctness'.........defined
President of Club Polk -
He stated in the video that component manufacturers try to filter out the noise but are only partially successful, so yes power conditioning would probably be a partial solution but I believe he also stated that the components create their own noise internally. I believe I have seen shielded speaker cables although I understand that they are not common compared to shielded interconnects but he commented that some would say that was the solution but he didn't agree because of the fact that it doesn't address the "noise on the line" as he referred to it, but he seemed to also be including the internal noise of the component as being part of that.
George / NJ
iFi nano iDSD DAC
iPurifier3
I’m sure someone will come up with a reason why this video is snake oil. Me personally,when I see someone say cables make no difference,I just move on. Great video. Thanks for sharing the link!See my profile for list of gear.
Good cables make a big improvement to the sound. However, I don't watch videos.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Codswallup! -
And great post Jesse. Thank You
Gardenstater wrote: »He stated in the video that component manufacturers try to filter out the noise but are only partially successful, so yes power conditioning would probably be a partial solution but I believe he also stated that the components create their own noise internally. I believe I have seen shielded speaker cables although I understand that they are not common compared to shielded interconnects but he commented that some would say that was the solution but he didn't agree because of the fact that it doesn't address the "noise on the line" as he referred to it, but he seemed to also be including the internal noise of the component as being part of that.
Ah yes, you're right. Components do create their own noise.Political Correctness'.........defined
Cables don’t any difference. Reference to mm2 ❤️
Cables are bull crap, don't make a difference at all...
Just send them to me, and I'll listen t- hehe, I mean, dispose of them for ya.
I use braided cables.
MM2 SDA cable
I liked the part when he said the name of the radio station they were using...
Since the speaker cables are the last link in the chain, would it be as beneficial to have all the cables be of similar construction (power, IC, etc.), or is it a case of too much of a good thing? For the record, I know cables make a difference, I'm just trying to grasp his ideas a little better.So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
I believe in that theory myself, keep all materials as equal as possible. If you like Wireworld gear, have it at all steps (IC, PC, Spk etc). I personally like AQ and have it in as many connections as I can afford.
That must be an I/C cable...probably Kimber? For speaker cable, I can't figure out what the third color of wire would be for.I use braided cables.
Looks to be the equivalent of a 4 conductor setup
Purple, black, gray, white- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Hey you know what, that video made me change my mind. I now do believe in certain kinds of noise rejecting cables. The only thing I needed to do was make the connection, remembering way back when cellular phones used to make our devices which produce sound would make it chirp, chirp, chirp from the cellular signals.
- Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
- Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
- Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
- Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
- Office-2.1 B&W Formation Duo and Bass
- Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
- Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
- Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
- Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
- Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
- Maintenance: Pro-Ject VC-S Record Cleaning Machine
Oh yeah, I see another shade of gray now. Only 48 to go!Looks to be the equivalent of a 4 conductor setup
Purple, black, gray, white"This may not matter to you, but it does to me for various reasons, many of them illogical or irrational, but the vinyl hobby is not really logical or rational..." - member on Vinyl Engine
Interesting video, so without breaking the bank, what would be some interconnects and speaker cables that could be used to the equivalent of what this gentleman is proposing? I imagine you'd need quality jumpers, interconnects, speaker cables. Especially for those of us using external amplifiers.
Here is a counter argument from Ethan Winer he developed a device to test wire differences:
https://www.youtube.com/watch?v=ZyWt3kANA3Q -
Your ears are the only device that accurately test wire difference. Look for OCC copper cables or betterGustard X26 Pro DAC
I thought everybody was running lamp chord.Don't take experimental gene therapies from known eugenicists.
Pay attention to gauge tooSamsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
It's sad that he thinks that his resistance, capacitance, and inductance are all there is to it. The ear is an instrument too, only we can't quantify what it hears, yet. Maybe when there is artificial intelligence. I'm sure there must be things going on, involving electrons ability to transmit musical information that he isn't measuring.
I'm doubtful of his null testing. I don't think it measures the difference in speed or transient response between different cables in a quantitative way. Music signals are way too complicated. If impedance of different cables at different frequencies is different (which it is), there's no way to have equal volumes across the whole audio frequency band.
George / NJ
iFi nano iDSD DAC
iPurifier3
Maybe part of the problem is that electronic measurement instrumentation has to sum things together, which is something that the human ear does not do, or at least it does it in a different way.George / NJ
iFi nano iDSD DAC
iPurifier3
"bank"???
That would be the Krux Kable by KnuKonceptz.The Krux Kable concept is simple, deliver a smooth sounding, high purity signal path for your analog audio signal. Construction begins with oxygen free copper (OFC) drawn in three distinct diameters(3D). This 3D design provides optimal signal transmission as low, mid, and upper ranges each travel these diameters with less distortion. Simplifying the design, we have reduced each core to only 7 strands yielding an 18 gauge conductor. Isolating smaller groups of copper minimizes strand interaction to maintain timing and spatial cues.
With the Krux Speaker Wire, that is where simple ends. A complex interlaced counter braid separates positive and negative conductors within the cable structure. Sixteen isolated conductors, 8 positive and 8 negative cores are woven to make one flexible, large gauge, speaker cable. In straight wire configuration the SPW16 is an 8 gauge (AWG) speaker wire. Configuring for Bi-Wire, the SPW16 yields four 11 gauge conductors.
The Krux Kable SPW16 is sold as bulk speaker wire by the foot to be assembled by the end user. Termination tips and instructions can be found under product specifications tab.
KnuKonceptz is known more in the car audio world. I cut my teeth doing car audio installs for myself and others. Some cars are noise free and others the complete opposite to a high degree. Cable placement and shielding is for sure used more so in that enviroment. There were/are many twisted and shielded cables in the car audio marketplace over the years.
I'm was considering the Krux Kable wire or more likley the ViaBlue SC2 wire for some DIY cables I plan to make and also using Furez plugs.ViaBlue SC2
ViaBlue Hybrid SC-2 V3 Silver Series speaker cables have stranded copper conductors plated with genuine silver. The ViaBlue SC-2 speaker cables have a transparent and three-dimensional acoustics and a brilliant, airy quality in the high range. Clean lows and basses homogeneously round out the acoustic pattern. Technically, all of the frequency ranges are cleanly and realistically represented and reproduced in a linear fashion. Both 4 mm2 leads of the SC-2 speaker cable is a rope lay design consisting of seven silver plated copper stranded lays with a total of 448 individual wire conductors. The basic burn-in time of the SC-2 speaker cables is App. 18-20 hours. The total burn-in time is App. 38-40 hours. (Exact times depend on temperature and location)
ViaBlue SC2 V3 Hybrid Silver/Copper Speaker Cable Specifications
• Version 3 is the latest SC2 release
• Silver and Copper Hybrid Speaker Wire
• 4 mm2-11AWG Construction 2 Conductor Cable
• Internally Twisted Conductors
• Rope lay design for improved sonic quality
• High Strand Inner Conductor Total 448 Strands per conductor
- Positive Conductor - 7 Inner Twisted Bundles of 64 Strands Silver Plated Copper
- Negative Conductor - 7 Inner Twisted Bundles of 64 Strands Tinned Copper
• Nominal Outer Cable Thickness 0.360"
• Weight: 0.328lb (5.25 oz.) per Meter
Their premade cables are nice!
5.2 A/V Setup | OLED TV - Sony Bravia XR A80J 77" | Source - Fire TV 4K Max, Wiim Pro | AVR - Anthem MRX 520 | Integrated - Musical Fidelity A5 | Speakers: Main - Boston Acoustics VS 336 | Center - Boston Acoustics VS 325c | Rear - Boston Acoustics VR-MX | Sub 1 - Boston Acoustics VPS 210 | Sub 2 - HSU VTF-2 mk3 -
These are clearly superior. Seeing as they offer more headroom....
A set of four is required.
https://youtu.be/DC0s6KqQz3g
