Odd issue with MagnifyMax SR and Vocla Tracks
smunger
Generally works fine with Direct TV and streamingg channels (some latency), but the vocal tracks are really hard to hear on the Sonny 4K Blu Ray player?
Answers
Most likely Something is forcing a 5.1 signal to the bar but the source is actually only 2.0. Do you have the player connected directly to the bar? If so, check the players audio output settings.
If running through the TV, check both the player and the TVs settings -
POlk is connected HDMI ARC to my 2019 LG. Sony 4K Player hooked into HDMI on TV. Should I have run the 4K player into the bar instead?
