Polk RTi12 tweeter resistor replacement recommendation question.
Tony M
Tony M Posts: 11,680
edited July 2020 in Troubleshooting
I read a thread where a guy used a Mills 12 watt resistor. He didn't state the ohms.
I read a schematic where it's 2.5 ohms / 5 watts.
Should I order the 2.5ohm / 12 watt Mills resistors?
For another set of speakers...
I can't find a 4.7ohm Mills replacement at Parts express.
They have 4.5 ohm and 5.0 ohms.
Which would be better?
thanks.
    Here's the schematic for the RTi12s;
    pitdogg2 Posts: 27,220
    They're many places besides parts express that sell vishay-mills resistors and yes you can go up in wattage but keep the same ohm value.
    Go to sonic craft and look at the resistors there. Jeff is good people.
    edited July 2020
    Will do.
    Sonic Craft it is.
    Will the 4.5 ohm replacement do in place of the 4.7 ohm that's on the board now?
    Or the 5.0 ohm?
    edited July 2020
    I'm ready to place an order...
    4.5 or 5.0 /12 watts.
    Will one make the tweeter brighter or softer or it doesn't matter much either way?
    There is no 4.7 Mills resistor made. :#
    There are some Daytons on the Parts express site. These are the ceramic style though.
    Dayton Audio DNR-4.7 4.7 Ohm 10W Precision Audio Grade Resistor
    Post edited by Tony M on
    Tony M wrote: »
    Really ??
    http://www.soniccraft.com/product_info.php/47-ohm-mills-mra-10-p-3662
    :o
    when was 4.7 =to 47?
    4.7+42.3=47
    Oh well I tried...
    Maybe next time click the link. It plainly states on the sight 4.7 ohm 10 watt. It's also an original mills not vishey-mills.
    Or hey call Jeff and ask he's a great guy to talk to.
    F1nut Posts: 51,939
    Tony M wrote: »
    Tony M wrote: »
    Really ??
    :o
    4.7+42.3=47
    Click the link and then apologize to Ivan.
    F1nut...I see 47 ohms in the link title. ;) I thought Ivan didn't see the coma between the 4 and 7 in my questions and then statement.
    Maybe Ivan should've said it says 47 ohms but will be a link to a Mills 4.7 ohm. Maybe you should criticize Ivan instead of me. ;)
    Why does the link show 47 ohms?!!
    I clicked on the link and saw 4.7 ohms at the top a minute ago.
    I won't apologize for the above stated reason, but I will...
    Thank you very much Ivan! ;) I really appreciate your link to the value of a Mills resistor I was searching for. B) I will now complete my order with the others I have in the cart and submit it for filling.
    Let the soldering begin. :)
    audioluvr Posts: 5,982
    They clearly don't carry a 47 ohm Mill's so why add a "." just for you? It's a link. Not a description. :D
    edited July 2020
    They don't?
    This is why Ivan should've put a , just for me. :D
    http://www.soniccraft.com/product_info.php/47-ohm-vishay-mills-mra-12-p-4687
    47 Ohm Vishay Mills 12 watt MRA-12
    Well technically that's a Vishay but I'll give you partial credit
