Dynamat
  • teekay0007
    teekay0007 Posts: 2,288
    Yes, the Dynamat Xtreme Wedge Pack will be plenty enough. With one Wedge Pack, I had enough to take care of SDA-2Bs, Monitor 10s and Monitor 5Jr+s. I Dynamated the carp out of the baskets of all drivers and PRs. I even had enough left over to make a couple of Dynamat headbands, just in case any ringing/distortion was internally sourced! B)
  • ozzy44
    ozzy44 Posts: 4
    edited May 2021
    Is KILMAT 80mil a good alternative for DYNAMAT 67mil Extreme? It certainly is a LOT cheaper! As for the ringing being "internally sourced", you have to remember that the sound of that "concert hall" coming from those Polks is just a GRAND ILLUSION, it can be as real or "canned" as your brain wants it to be!
  • Gardenstater
    Gardenstater Posts: 4,785
    I would be surprised if very many people have used that product here. But even if someone joins in I think it would be a good bet for you to read the reviews on amazon
    https://www.amazon.com/Kilmat-Deadening-Automotive-Insulation-dampening/dp/B082Q2J2T4?ref_=ast_sto_dp
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    F1nut Posts: 51,877
    ozzy44 wrote: »
    It appears to be a like/kind product. The only question to look into is the adhesion quality. I once used a like/kind Dynamat product that after a period of time started to fall off. I've never had that problem with Dynamat Xtreme.
    As for your last comment, you have much to learn.
