Dynamat
BinKY188_5
How much Dynamat is needed for a pair of SDA SRS? Is 4 sq.ft. enough?
https://www.ebay.com/sch/i.html?_from=R40&_trksid=m570.l1313&_nkw=dynamat+wedge+pack&_sacat=0&LH_TitleDesc=0&_osacat=0&_odkw=dynamat
Yes, the Dynamat Xtreme Wedge Pack will be plenty enough. With one Wedge Pack, I had enough to take care of SDA-2Bs, Monitor 10s and Monitor 5Jr+s. I Dynamated the carp out of the baskets of all drivers and PRs. I even had enough left over to make a couple of Dynamat headbands, just in case any ringing/distortion was internally sourced!
Is KILMAT 80mil a good alternative for DYNAMAT 67mil Extreme? It certainly is a LOT cheaper! As for the ringing being "internally sourced", you have to remember that the sound of that "concert hall" coming from those Polks is just a GRAND ILLUSION, it can be as real or "canned" as your brain wants it to be!
I would be surprised if very many people have used that product here. But even if someone joins in I think it would be a good bet for you to read the reviews on amazon
https://www.amazon.com/Kilmat-Deadening-Automotive-Insulation-dampening/dp/B082Q2J2T4?ref_=ast_sto_dpGeorge / NJ
Onkyo A-8017 integrated
iFi nano iDSD DAC
iPurifier3
iDefender w/ iPower PS
It appears to be a like/kind product. The only question to look into is the adhesion quality. I once used a like/kind Dynamat product that after a period of time started to fall off. I've never had that problem with Dynamat Xtreme.
As for your last comment, you have much to learn.Political Correctness'.........defined
