Is it possible to send yourself a Private Message
BlueFox
I can’t get it to work.
You seem to have your answer...
Puzzled as to why you would want to talk to yourself?
I worry about you sometimes.Political Correctness'.........defined
President of Club Polk -
Apparently. I was hoping it was operator error.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
It was operator error. Just tested it and it worked.2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Interconnect Cables, AudioQuest Niagara 7000 w/Dragon, WAY power cables for all other sources.
I tried it. Only saw the one message I sent.
The weird part was leaving the conversation with myself. But I'll call myself tomorrow to check in.I disabled signatures. -
Only if they want to. Still waiting!!!!2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Interconnect Cables, AudioQuest Niagara 7000 w/Dragon, WAY power cables for all other sources.
You're Killin me Todd...
Don't hold your breath
Interesting. I wonder if there is some setting needed to get it to work. Thanks for the info.Lumin X1 file player, Westminster Labs interconnect cable
I can promise you the responder will be an idiot. 😀2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Interconnect Cables, AudioQuest Niagara 7000 w/Dragon, WAY power cables for all other sources.
No you send it to your name and it says just you -
When trying to do it I put in my name. When I go to message area the name clears.Lumin X1 file player, Westminster Labs interconnect cable
Trust me it's doing you a favor Bud....
You aren't that interesting to converse with
Lol -
Great thread. If nobody messages you. You can always try messaging yourself. Why didnt I think of this
Randy-Maine
2ch-RTA15tl crossover upgrade
by David WMG
Yamaha cr1000 cr2040
HT-Yamaha Parasound Acurus
Yes. Thanks for the help.Lumin X1 file player, Westminster Labs interconnect cable
Best thread of 2020!2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Interconnect Cables, AudioQuest Niagara 7000 w/Dragon, WAY power cables for all other sources.
boston1450 wrote: »Great thread. If nobody messages you. You can always try messaging yourself. Why didnt I think of this
Yes but if you do that messaging oneself my dad told me you'll go blind....
Proceed with caution. Once you receive it and read it, it will no longer be private.
I'm not politically incorrect!
Yes you are!
No I'm not!
Your mother is fat!
Not she's not!
Working for me...Gustard X26 Pro DAC
Funny stuff here. The old-school method still works.Don't take experimental gene therapies from known eugenicists.
Seems to be an iPad/Vanilla issue. Trying it today, it still didn't work. Then I tried another name. Same problem. Tried another name, then it worked. After that it worked fine for any recipient. Then I exited out of the PM, and tried again. Same problem. It takes trying different names and at some point, after multiple names, it starts to work. After that, it is okay.Lumin X1 file player, Westminster Labs interconnect cable
Luckily I added @Hermitism to my PM to myself before I left the conversation with myself, because I changed my mind and then panicked, but he was able to add me to my conversation with myself again, and I can see all the things I said to myself that I was feeling sentimental over after leaving the conversation with myself. Since yesterday. When I started the conversation with myself.I disabled signatures.
The reason I was doing that is because I had stroke almost two years ago. One of the stroke side-effects was making my short term memory erratic. For example, I would learn a member's name, and then forget it. So I created a PM with the Vanilla name and the real name. I hope that is okay with everyone.Lumin X1 file player, Westminster Labs interconnect cable
^^^^ and suddenly the thread isn't as comical. Whatever works for you,
go for it. I applaud your reasoning and tenacity to stick around.
But some of the @msg posts still have me smiling...So, are you willing to put forth a little effort or are you happy sitting in your skeptical poo pile?
http://audiomilitia.proboards.com/ -
It's okay with me Bud, pretty sure you know I was just kiddin' around. I think everyone was.
There's probably a note app that might work well for you, too. Evernote, Google Keep, and whatever it is that Apple has built in with the iPad. Might even offer faster access than having to scroll through an old PM in your Polk Inbox.I disabled signatures. -
No problem. I realized people were joking. It was a crazy topic.
Only the lonely"if it's not fun, it's not worth it & remember folks, "It's All About The Music"!!
I try to ignore myself all the time. I haven't had much luck -- I should ask my wife how it's done.
