Is it possible to send yourself a Private Message
BlueFox
BlueFox Posts: 15,250
I can’t get it to work.
    pitdogg2 Posts: 27,151
    You seem to have your answer...
    Puzzled as to why you would want to talk to yourself?
    F1nut Posts: 51,871
    I worry about you sometimes.
  • BlueFox
    Apparently. I was hoping it was operator error.
  • tratliff
    tratliff Posts: 1,799
    It was operator error. Just tested it and it worked.
    msg Posts: 10,452
    I tried it. Only saw the one message I sent.
    The weird part was leaving the conversation with myself. But I'll call myself tomorrow to check in.
    edited June 2020
    tratliff wrote: »
    So did they answer back ?
    :D:D:D
  • tratliff
    Only if they want to. Still waiting!!!!
    You're Killin me Todd...
    Don't hold your breath :p
  • BlueFox
    Interesting. I wonder if there is some setting needed to get it to work. Thanks for the info.
    edited June 2020
    BlueFox wrote: »
    No you send it to your name and it says just you
  • BlueFox
    When trying to do it I put in my name. When I go to message area the name clears.
    BlueFox wrote: »
    Trust me it's doing you a favor Bud....
    You aren't that interesting to converse with
    Lol
  • boston1450
    boston1450 Posts: 7,758
    Great thread. If nobody messages you. You can always try messaging yourself. Why didnt I think of this
    Randy-Maine
    2ch-RTA15tl crossover upgrade
    by David WMG
    Yamaha cr1000 cr2040
    HT-Yamaha Parasound Acurus
    MIT BJC Cs1000p Polk Rotation
  • BlueFox
    Yes. Thanks for the help.
  • tratliff
    Best thread of 2020!
    boston1450 wrote: »
    Yes but if you do that messaging oneself my dad told me you'll go blind....
    :D:D:D
    Viking64 Posts: 7,582
    Proceed with caution. Once you receive it and read it, it will no longer be private.
    audioluvr Posts: 5,970
    I'm not politically incorrect!
    Yes you are!
    No I'm not!
    Your mother is fat!
    Not she's not!
    Working for me...
    xschop Posts: 5,247
    Funny stuff here. The old-school method still works.
  • BlueFox
    Seems to be an iPad/Vanilla issue. Trying it today, it still didn't work. Then I tried another name. Same problem. Tried another name, then it worked. After that it worked fine for any recipient. Then I exited out of the PM, and tried again. Same problem. It takes trying different names and at some point, after multiple names, it starts to work. After that, it is okay.
    msg Posts: 10,452
    Luckily I added @Hermitism to my PM to myself before I left the conversation with myself, because I changed my mind and then panicked, but he was able to add me to my conversation with myself again, and I can see all the things I said to myself that I was feeling sentimental over after leaving the conversation with myself. Since yesterday. When I started the conversation with myself.
    msg Posts: 10,452
    I'm glad I'm back.
    msg Posts: 10,452
    Me too.
  • BlueFox
    The reason I was doing that is because I had stroke almost two years ago. One of the stroke side-effects was making my short term memory erratic. For example, I would learn a member's name, and then forget it. So I created a PM with the Vanilla name and the real name. I hope that is okay with everyone.
  • polrbehr
    polrbehr Posts: 2,842
    edited June 2020
    ^^^^ and suddenly the thread isn't as comical. Whatever works for you,
    go for it. I applaud your reasoning and tenacity to stick around.
    But some of the @msg posts still have me smiling...
    msg Posts: 10,452
    edited June 2020
    It's okay with me Bud, pretty sure you know I was just kiddin' around. I think everyone was.
    There's probably a note app that might work well for you, too. Evernote, Google Keep, and whatever it is that Apple has built in with the iPad. Might even offer faster access than having to scroll through an old PM in your Polk Inbox.
  • BlueFox
    No problem. I realized people were joking. It was a crazy topic. :)
  • tophatjohnny
    tophatjohnny Posts: 4,189
    Only the lonely
    mhardy6647 Posts: 35,135
    I try to ignore myself all the time. I haven't had much luck -- I should ask my wife how it's done.
