Which color do you like
  • aprazer402
    aprazer402 Posts: 3,352
    edited June 2020
    Champlain
    Did your installer state a color preference? They see a lot of these. Best bet, go with the wife's choice.
  • Willow
    Willow Posts: 11,216
    Shale Grey
    Thinking about what John said, the porch is 20 ft long and 6 ft wide. The grey might just look washed out.
  • Willow
    Shale Grey
    He says Champlain. My wife is 50/50
  • tonyp063
    tonyp063 Posts: 1,128
    Champlain
    I'm not a landscape designer. I don't play one on TV & I didn't stay at a Holiday Inn last night.
    But....
    Champlain. Hands down.
    They plain grey will be boring & washed out.
    txcoastal1 Posts: 13,499
    Will they include creating new weep holes above the brick line?
  • Willow
    Shale Grey
    txcoastal1 wrote: »
    Yes he mentioned it as did we. The ones for the porch are actually 45 mm the ones you see are 60mm they will be used in the walkway
