LSi15 Feet Insert Repair
skrol
The inserts on the bottoms of my LSi15s are loose. I have spikes screwed into them presently and the speakers are wobbly. The inserts don’t look like a screw-in type. They may be pressed in. I was hoping to epoxy them in but I don’t see a way to remove them to get epoxy in the hole.
Anyone have experience with these or ideas? I may have to drill new holes and use new screw-in inserts.
Stan
Stan
Stan
Main 2ch:
HT:
Other stuff:
Main 2ch:
HT:
Other stuff:
They can be repaired easily and quite cheaply by ordering LSiM 705's from Adorama...
Somebody has not been kind to the bottom.
I agree Stan, those look like press fit. Run a bolt into it all the way, then use the bolt head to attach a vise-grip to and pull straight up.Political Correctness'.........defined
President of Club Polk -
Does it have split sides like this?
If it's barbed like this one pulling it out will rip out the hole.
Someone was not too kind to these speakers, at least the bottoms. There are a few good chips out of the lacquer. The tops look very good still.
They look kind of rounded (not sure why) and serrated or possibly barbed. I was afraid to yank it out and mess up the hole but that may be the only way. Worst case, I could yank them, fill the hole with some kind of filler and re-drill.Stan
Main 2ch:
HT:
Other stuff:
You know Stan, you might be better off drilling new holes for new threaded inserts.Political Correctness'.........defined
I'm going to try yanking one of the inserts out and see that is there. I am end up just re-drilling and installing new inserts.Stan
Main 2ch:
HT:
Other stuff:
Ok, good luck.Political Correctness'.........defined
The original locations look pretty ideal for stability. I am thinking about removing them, filling the holes, drill and install new inserts. When we talked last week you mentioned epoxies that had different fillers. If I can pick your furniture restoration brain, is there something that you would recommend to fill the holes?Stan
Main 2ch:
HT:
Other stuff:
A wood dowel should do the trick.Political Correctness'.........defined
Glued in, of course.Political Correctness'.........defined
UghPolitical Correctness'.........defined
That didn’t take long, lol!
Do not use Gorilla Grip. All it’s good for is a weak bond and a permanent mess.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
New thought... Outriggers
https://www.parts-express.com/dayton-audio-os-2hd-outrigger-speaker-spike-set-heavy-duty-with-black-steel-base-2-pcs--240-772
https://www.parts-express.com/dayton-audio-oa-4-outrigger-speaker-spike-set-with-steel-base-4-pcs--240-771Stan
Main 2ch:
HT:
Other stuff:
That would be my move.^^^The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
You might check these out also, though they are more expensive. They would attach to your plinth using the factory insert locations, which only need to be fairly snug, but not cranked down to 1,000 ft-lbs...
https://soundocity.com/
https://soundocity.com/product-category/outriggers/
I have the "steel-spike" versions on my current media room towers (LSiM707s), my previous towers (RTiA7s) and my two-channel system towers (Wharfedale EM99s). The outriggers are quite nice, made out of beefy steel, and make the speaker more stable with the wider contact points.
No affiliation w/ Sondocity - just a happy customer since 2010!
Main HT:JVC DLA-RS45135" Elite Screens fixed frame, 1.1 gainMarantz SR7007 (operating as pre-pro)Emotiva XPA-1 x3 (L+C+R), UPA-7 (surrounds)Oppo BDP-103D/BDP-83Toshiba HD-XA2Panamax M5410 Pro x3Polk LSiM707s, LSiC706, 80 F/X-LS, 65-RTSeaton Sound/MCCA MFW "Turbo" + custom Dayton SA1000 sub amp (orig. AV123 MFW-15)Velodyne SMS-1I/Cs: MP 12ga/4-cond (fronts); MP 12ga (surrounds), MP HDMI (all sources), some BJC sprinkled thruoutHarmony EliteSalamander Triple 40 C/B* still need to sell older but mint gear!! -
These pictures show the 707's outriggers:
^^ before removing the super-sliders
^^ front outrigger with steel spikes fully inserted
Thanks they do look beefier than the Parts Express versions.Stan
Main 2ch:
HT:
Other stuff:
Back on the topic of repairing my LSi15 feet.... I managed to pull one of the inserts out. They are barbed and the base appears to be MDF.
Post edited by skrol onStan
Main 2ch:
HT:
Other stuff:
Put epoxy on the hole, and push the barbed insert back in. Done.
Just make sure you don't get any epoxy pushing up into the threads.Political Correctness'.........defined
Run some grease up the threads and you won't have to worry about the epoxy getting in them. Just make sure the outside is clean and free of it.
Thanks for the feed back. I haven't been hanging on the forums for a few weeks but I did make the repairs and some others. I used my Dremel routing bit to cut a grove to get a bit more epoxy in the hole. Also, I found some screws to fit the inserts to keep the epoxy from gumming up the threads. I first greased the threads to make sure they didn't get glued into the inserts.
It all worked out great. I am surprised at how much cleaner the low end sounds with the spikes more secure. I guess everything does matter.
Stan
Main 2ch:
HT:
Other stuff:
Good job Stan.Political Correctness'.........defined
I have some big chips in the lacquer. What is a good way of repairing?Stan
Main 2ch:
HT:
Other stuff:
Looking at that bottom, a complete refinish is your only option.Political Correctness'.........defined
I had thought about making new ones but probably not up for it. The other thought was to fill the deep chipped out areas and repaint.Stan
Main 2ch:
HT:
Other stuff:
I’ve done a repair similar
I actually cross scarred deep scratches into the surface then sanded. Skimmed with bondo and sanded ...treated it like auto body repair
Looked new when I was done
That is exactly what I was thinking, bondo.Stan
Main 2ch:
HT:
Other stuff:
