Dell P2011H Tilt Question
So, this Dell is suppose to have this feature wherein you can turn the screen from horizonal to vertical...while I can physically do this the contents on the screen stay in the horizontal position....looked at online pdf and it did not go into specifics on how this works...did download what I thought was the most recent driver but still didn't help...
thoughts?
Computer room Hegeman 1 SpeakersM&K VX-80 subKenwood DP-7010Cambridge Audio CXC Transport Rega DACPrimaLuna Prologue Four AmpAric Audio Tube PreampGarage Jennings Research SquareCustom tube preampCrown XLS-1000Denon DCD-1500II Modded MSB Link DAC
    txcoastal1 Posts: 13,134
  • ZLTFUL
    ZLTFUL Posts: 5,640
    Ron is correct above. You have to change the orientation from Landscape to Potrait in your computer's display settings.
    Monitors are mostly "dumb" devices that are only displaying the data sent to them so if you are sending a landscape oriented "picture" to them, that's what they display.
