Crossover settings
terrancew5
Hi im running dual psw10s. Im trying to find out what is the proper sertings i should have on both subs. Please help..
That depends. What are your other speakers?
Im using the jaton avn 515 system. I believe they can play down to 50 hz but as of right now i have them set to 80 hz
That's some sort of system powered by the amp in the subwoofer, correct?Political Correctness'.........defined
President of Club Polk -
Generally 80 is a safe place to start😊Samsung 60" QN65Q7FAMFXZA QLED, Outlaw Audio 976 Pre/Pro, Samsung BDP, Amazon Firestick, Phillips CD Changer
*all connected w/Premiere ICs
4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s -
Not sure. I don't have the sub that goes with that set up..just the center and the front left and right
terrancew5 wrote: »Not sure. I don't have the sub that goes with that set up..just the center and the front left and right
Ok, well some of those all in one deals are designed to be used as a system with preset parameters. As such using some of the system as you are doing might not result in the best performance. YMMV.Political Correctness'.........defined
They speakers actually sound pretty good as far as clarity at 80 hz..i know they are not the best i can get but good enuff for my pockets right now lol..im just stuck on my sub crossovers
Set at 80Hz.Political Correctness'.........defined
Thank u
I personally would set them at 120Hz... THx would be 80Hz across the board.
