Crossover settings
Hi im running dual psw10s. Im trying to find out what is the proper sertings i should have on both subs. Please help..
  • DaveHo
    DaveHo Posts: 3,480
    That depends. What are your other speakers?
  • terrancew5
    terrancew5 Posts: 5
    Im using the jaton avn 515 system. I believe they can play down to 50 hz but as of right now i have them set to 80 hz
    F1nut Posts: 49,793
    That's some sort of system powered by the amp in the subwoofer, correct?
  • gp4jesus
    gp4jesus Posts: 1,969
    Generally 80 is a safe place to start😊
    Samsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work
  • terrancew5
    terrancew5 Posts: 5
    Not sure. I don't have the sub that goes with that set up..just the center and the front left and right
    F1nut Posts: 49,793
    terrancew5 wrote: »
    Ok, well some of those all in one deals are designed to be used as a system with preset parameters. As such using some of the system as you are doing might not result in the best performance. YMMV.
  • terrancew5
    terrancew5 Posts: 5
    They speakers actually sound pretty good as far as clarity at 80 hz..i know they are not the best i can get but good enuff for my pockets right now lol..im just stuck on my sub crossovers
    F1nut Posts: 49,793
    Set at 80Hz.
  • terrancew5
    terrancew5 Posts: 5
  • whoban72
    I personally would set them at 120Hz... THx would be 80Hz across the board.
