Crossover settings
Hi im running dual psw10s. Im trying to find out what is the proper sertings i should have on both subs. Please help..
  • DaveHo
    DaveHo Posts: 3,583
    That depends. What are your other speakers?
  • terrancew5
    terrancew5 Posts: 5
    Im using the jaton avn 515 system. I believe they can play down to 50 hz but as of right now i have them set to 80 hz
    F1nut Posts: 51,986
    That's some sort of system powered by the amp in the subwoofer, correct?
  • gp4jesus
    gp4jesus Posts: 2,019
    Generally 80 is a safe place to start😊
    *all connected w/Premiere ICs
  • terrancew5
    terrancew5 Posts: 5
    Not sure. I don't have the sub that goes with that set up..just the center and the front left and right
    F1nut Posts: 51,986
    terrancew5 wrote: »
    Ok, well some of those all in one deals are designed to be used as a system with preset parameters. As such using some of the system as you are doing might not result in the best performance. YMMV.
  • terrancew5
    terrancew5 Posts: 5
    They speakers actually sound pretty good as far as clarity at 80 hz..i know they are not the best i can get but good enuff for my pockets right now lol..im just stuck on my sub crossovers
    F1nut Posts: 51,986
    Set at 80Hz.
  • I personally would set them at 120Hz... THx would be 80Hz across the board.
