ROGUE PREAMP
pearsall001
pearsall001 Posts: 5,256
I'm think about giving some "Tubes" a try. I have an opportunity to pick up a new ROGUE RP-1 preamp at a great price. From what I can gather it receives stellar reviews. It has a HT Bypass & remote that is just what the Dr. ordered. Does anyone have any experience with the RP-1 or Rogue gear in general. I like that their made local & that the owner is great to work with. Comments, thoughts, other recommendations welcomed. I was originally thinking about a new DAC but I think this is a better move.
  • WLDock
    WLDock Posts: 3,073
    That's a very cool preamp! Go for it! gce posted up some feedback of his RP-5 awhile back: https://forum.polkaudio.com/discussion/167654/rogue-rp-5-review/p1
    Been wanting to try a Rogue Audio pre myself for a bit and especially the newer platform RP-1. I've listened to their stuff many years at AXPONA and find the company's story pretty cool. Some day...
    https://www.dagogo.com/an-interview-with-mark-obrien-of-rogue-audio/
    https://www.soundstageglobal.com/index.php/blogging-on-audio/248-s-andrea-sundaram/817-a-day-at-rogue-audio
    https://twitteringmachines.com/road-tour-rogue-audio/
  • jdjohn
    jdjohn Posts: 3,336
    I have a Rogue Audio Triton phono pre-amp that I love. If I weren't so entrenched in a PS Audio stack, I would probably go for a Rogue stack.
    audioluvr Posts: 5,897
    If you get it let me know. I'll send you some 12AU7' s to roll.
  • CottageChz
    CottageChz Posts: 416
    A local shop here sells their stuff. It seems pretty nice, and I like that it’s made here in PA. Hopefully someday I can check it out. Post a review if you pull the trigger!
  • Faustin
    Faustin Posts: 1,151
    I have a Rogue Cronus Magnum II integrated amp. Very well built. Really like it. Have not had any problems or issues with it.
  • WLDock
    WLDock Posts: 3,073
    Faustin wrote: »
    Very nice!
    nooshinjohn Posts: 25,901
    I had a couple versions of the Rogue Perseus preamp, and found them to be able performers, but the Pass Labs preamps were a better fit for my amplifiers. I would consider going with a used Pass X1 as an option.
  • pearsall001
    audioluvr wrote: »
    The RP-1 is ordered in silver. It should be here in a week to 10 days.
    I'm going to stick with the stock tubes for awhile to get the feel for them.
    After that I just might take you up on your kind jesture.
    It comes stock with JJ's.
    What are your recommendations.
    Thanks 🍺
    Well on my system I like the Raytheon tubes but you may not. I've never tried the JJ's so those could be ideal for your likes. PM me when you get the urge to roll.
  • pearsall001
    audioluvr wrote: »
    You got it. Thanks again for the kind offer.
  • dhart86
    dhart86 Posts: 1,594
    audioluvr wrote: »
    Thanks 🍺
    I'm a tube head, You will want to get some NOS tubes tubes, trust me! But I think it's a good idea to start with stock so you can get a feel. The amp won't be at it's best till you get some good tubes. Psvane and Gold lion are the only new production tubes I recommend but NOS are the way to go eventually. Enjoy and let us know what you think
    Main Rig:
    Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
    Second Rig:
    Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded)
  • pearsall001
    Nothing like a never ending rabbit hole. It sounds like a lot of fun awaits. 👍🍺
  • acmf74
    acmf74 Posts: 937
    I currently have the Rogue Perseus magnum. It's a solid piece of equipment, it also has a phono input and HT bypass switch. I like the sound more from the Rogue than my old Cary. I also have the RCA cleaptops in it which I find to be a tad bright. I'm looking for another set of tubes that can tame it abit off the highs.
  • pearsall001
    Looks like delivery is set for Wed 6/17. Can't wait to get 'er set up & get these old crusty ears on it.
    If all goes well my eyes are focused next on the Rogue Model 100 tube amp.
    Things are looking up in tubevile.
