HTS-10 Subwoofer Auto-on not working
lloyd125
I have a Polk HTS-10 Sub which I just bought, sub sounds fine, but I cannot get the Auto turn on to work from standby.
I have tried both LFE connection and RCA connection with crossover set to max. Tried various crossover settings on Receiver for main speakers from 40Hz to 100Hz.
Is this a common problem on the HTS-10, is it defective or can it be made to work?
Any help appreciated, unfortunately the HTS-10 does not have a 3rd setting to have the unit powered on all the time, so the auto on needs to work.
Does anyone ever answer these questions? I’ve got the same problem
Both of you should contact Polk customer service directly as they do not monitor this section.Political Correctness'.........defined
President of Club Polk -
I have the same problem, anyone got an answer to this?
