Speaker placement and insulation protection questions
I am building a home in Wisconsin and would like some help in final decisions on speaker placements and protecting them from insulation.
I have the following speakers already:
(2) 265RT
(2) 65RT
S35 for center channel
Pre-construction brackets for the 265s and 65s
The room setup:
-12 foot ceiling in the great room
-Ceiling steps down to around 9 foot surrounding this area
-Room dimensions are approximately 16 foot by 17 foot
-exterior wall and anything above 9 foot are 2x6 construction and will be blown in blanket (bib) insulation. Ceilings are blown in cellulose
-rockwool safe n sound on all other interior walls
-tv will be mounted above fireplace above mantel
The picture shows anticipated speaker locations for the front speakers. I know one is on an exterior wall which is not preferred but I have to make due with what I have.
For the rears, I am considering just installing them in the ceiling due to proximity to the couches and being so high up. Any thoughts there on the placement?
I also want to protect from the loose insulation. I was considering these:
https://www.backboxx.com/backboxx-tm-application
Any thoughts there? Especially with that exterior wall 265rt. Should I just make a baffled box out of Rigid foam board instead?
Please help!
Answers
    F1nut Posts: 52,164
    Never put a TV above a fireplace.
  • polrbehr
    polrbehr Posts: 2,861
    edited May 2020
    Agreed, unless it's a low gas-fired unit and the mantel isn't more than 3-4' high. I also don't favor having a heat source directly below a TV, might shorten its life.
    But he may not have much choice with this room?
    As for the Backboxx, it looks like a good way to keep loose insulation away from the speakers, give it a shot.
  • CopperTop42
    It is the only logical place to put the TV it will be 36-42 inches above the fireplace. We do not use the TV while the fireplace is going in our current home and that will continue. We will have a fireplace tv mount bring it into better viewing position.
    My primary concern as I stated is protecting the one exterior wall 265RT and placement of the rear speakers due to the height of the rear “wall”.
