DYI sub, What amp should I use
Alright guys dont want to beat a dead horse, But there is a lot of new stuff on the market now, And my question is what kind of amp should I use and speaker for my DYI sub, I want the freaking thing to shake and rumble my house, Also what is better ported or sealed for what I am looking for, Downward fire ? Please no links I think I hit a lot of them, There is a boat load of smart people on this site and I value your input. My reciever is a Denon AVR-3805.
Thanks for all who have input. Keep in mind DEEP and LOW, It will be for my HT.
Cliff
Post edited by musiclover on
  • Airplay355
    Airplay355 Posts: 4,298
    edited January 2005
    ported would probably be better for HT, and any high powered amp is good as long as it can handle the ohm load of the driver you use
  • musiclover
    musiclover Posts: 11
    edited January 2005
    Should I use multiple speakers ? What size speaker should I use, What amp is better? parasound, carver samson ,etc
    Cliff
  • Codey
    Codey Posts: 188
    edited January 2005
    Check out the Adire Tempest, it's a 15" DVC. I built one into a ported box with a 250 watt plate amp and love it. A few threads down I posted it's frequency response if you're interested in how low it goes.
    Outlaw 950
    GFA-555
    GFA-545
    GFA-2535
    RTi8s
    CSi5
    FXi3s
    214L Vented Tempest
    250w BASH amp
    Toshiba HDA1
    Toshiba 44" DLP
    NAD 533 Turntable
    Tripplite HT3100
    Xbox 360
  • Airplay355
    edited January 2005
    how you design your sub has alot to do with the room it will be in. how big is your room? what drivers are you looking at?
    you should get a box building program that will let you put the small parameters of the driver in and will automatically calculate things for you like enclosure size, port length and give you an fr curve.
    for a sub a good pro amp with high power would be fine. crown and samson are good names. check out parts express for plate amplifiers and crown amps too. ive never heard a sub powered with an amp like a parasound which is geared more towards quality then quantity so i dont really know how that would effect things. i imagine that youd be better off with a high powered pro amp then a lower powered quality amp.
  • musiclover
    edited January 2005
    Room is 24 by 16 , where can i get such program to calculate volume and size of box ?
    Tony M Posts: 11,626
    edited January 2005
    I've heard svs's do what you want (but) since your here at POLK
    click over to new products and check out the biggest sub POLK
    has.;)
  • Airplay355
    edited January 2005
    i had one called box plot but i'm not sure if it was any good and i don't remember where i found it. google it and see what ya come up with. win isd is also a program i think but im not sure if it plots boxes or just makes fr curves.
    you have a pretty big room, i wouldnt skimp on the sub. adire makes nice drivers, as does stryke audio.
    how much do you want to spend?
  • musiclover
    edited January 2005
    looking to spend about 1,000.
  • Codey
    Codey Posts: 188
    edited January 2005
    Adire has plans on their website for their woofers. And for $1000 you could build two if you really wanted to reduce your house to a pile of ruble.
    Outlaw 950
    GFA-555
    GFA-545
    GFA-2535
    RTi8s
    CSi5
    FXi3s
    214L Vented Tempest
    250w BASH amp
    Toshiba HDA1
    Toshiba 44" DLP
    NAD 533 Turntable
    Tripplite HT3100
    Xbox 360
  • Mjr7531
    Mjr7531 Posts: 856
    edited January 2005
    The tempest can go plenty deep and loud enough for just about anybody, model a box with WinISD, you can do some really cool stuff with it.
    I've designed a 12 ft^3 at about 18Hz I think that was 15-240Hz +-3dB (Theoretical, without roomgain) That will most like unseat your house off the foundation. Parts Express has good Plate Amps you would like to look into, along with everything you may dream to do DIY,
    Parts Express Plate Amplifiers.
    You can get an Amp for about 300-400 dollars, a sub for 150 (Tempest) wood for about $40-50 (3/4 or up is a must) and finishing, paint (10-20 bucks) or vinyl (Parts Express also, about 25-40 for what you are doing, and then 20-40 bucks for misc. stuff, and you are looking at a $2000 store bought sub (If not more.) for only 650-700 bucks!
    good luck on your DIYing,
    Matt
  • goingganzo
    goingganzo Posts: 2,793
    edited January 2005
    i will say go with this sub
    http://www.ascendantaudio.com/Avalanche%2018.htm
    and a nice 500-1000 wat plateamp
