What to buy to hook up RM7 SAT Black speakers?
Hi, my house's previous owner left two RM7 SAT Black speakers on the wall and a bunch of wires. I think the previous owner must have had a home theatre system and took all the moveable pieces with him.
I want to take advantage of the speakers to build a home theatre system and am wondering what other pieces that I need to buy.
Any ideas? Thanks!
Answers
    F1nut Posts: 51,760
    Are the speakers on the front, side or back wall?
  • guodah77
    guodah77 Posts: 3
    Hey, thanks for replying! They are on the back wall.
    F1nut Posts: 51,760
    edited May 2020
    Ok, so they would be used as rear surrounds and do not need to timbre match the L/C/R speakers.
    At a minimum, you need to buy two front (left and right) speakers, a matching center channel speaker, an AVR, cables and any sources, such as a Blu-ray player. I presume you already have a TV.
  • guodah77
    guodah77 Posts: 3
    Thanks a lot! Just googled around, looks that I need to invest five or six hundred dollars at least to make it work. Maybe I will wait until later. Thanks anyway!
    tonyb Posts: 33,072
    Way more than 5 or 600. That will just cover the receiver.
    F1nut Posts: 51,760
    edited May 2020
    What tonyb said and I forgot one very important piece, a really good subwoofer.
