What next to improve my sound
    Viking64 Posts: 7,587
    Why plug the....bass port? :o
  • rooftop59
    rooftop59 Posts: 8,120
    Milito wrote: »
    rooftop59 wrote: »
    Milito wrote: »
    One of the problems I have is the space I have available to put anything new. The wife won't go for audio equipment laying around everywhere. The new classic or P5 probably won't fit in the space available. I'm going to have to see what I can do as far as space.
    Which helped your sound more, the P5 or a streamer? If I could find a space to put either one.
    Have you seen the actual size of a squeezebox touch? Very small and doubles as a clock. I would seriously consider a preamp and a touch to try out better quality streaming. Of course a lumin is better, but have a decent system and ears and the difference between my Bryston and touch is very slight...and if you don’t like the touch you can just move it along.
    Thanks I'll check it out.
    Looks like a pretty solid option: https://www.ebay.com/itm/Logitech-Squeezebox-Touch-Remote-USB-Ethernet-Wireless-Audio-Music-Player-Stream/313074728930?_trkparms=aid=111001&algo=REC.SEED&ao=1&asc=20160908105057&meid=a86634eba00546da86af13b38c51e3f1&pid=100675&rk=1&rkt=15&mehot=none&sd=313074728930&itm=313074728930&pmt=1&noa=1&pg=2380057&brand=Logitech&_trksid=p2380057.c100675.m4236&_trkparms=pageci:89bf4d0c-908f-11ea-a33b-74dbd1803110|parentrq:f05ec6c91710aa652940ff85ffe4dd64|iid:1
    Game Room 5.1.4:
    Bedroom 2.1
  • afterburnt
    afterburnt Posts: 7,892
    My 2 cents.. I have the Yamaha 1060 and I got the Parasound P5 with HT bypass added a streamer and that was a game changer.
    I started with a Auralic Aries Mini and then moved that to another rig an added a CA 851N. Having the pre and streamer took my modest rig to another level.
    For $1000 bucks you could pick up a used P5 and Bluesound Node and be set.
    We followed virtually the same path but I am running a CXN. I didn't start liking my 707's until I got of the computer and got on the streamers.
  • rburgess714
    rburgess714 Posts: 618
    Milito wrote: »
    It was a cumulative effect but I added the P5 first and don’t laugh used a chromecast dongle until I could get a dedicated streamer. I have to say for $35 it wasn’t bad.
    Living Room
    Parasound HINT 6, Yamaha Aventage RX-A 1060, Oppo 103D, Cambridge Audio Azur 851N, KLH Model 5s, Polk CSi A6, Samsung 65" LED
    Office
    Yamaha A-S501, Auralic Aries Mini, LSiM 703s
    Douglas Connection ICs and Cables
  • rburgess714
    edited May 2020
    Living Room
    Office
  • rooftop59
    Milito wrote: »
    I don’t think that’s a bad idea at all! The chromecast audio for about $50 new on eBay is a great deal and using the optical out actually sounds pretty darn good! It will absolutely sound better than a usb stick into your receiver...
    Game Room 5.1.4:
    Bedroom 2.1
  • PSOVLSK
    PSOVLSK Posts: 5,396
    I use a FireTv. Not sure how it compares to the Chromecast, but I like it.
  • Milito
    Milito Posts: 2,003
    Still waiting for our checks to arrive and will see what's available then. Thanks for all of the suggestions.
