Adcom GFP-750
I’ve been hunting one of these for years....if any has a line on one, I am most interested.
A Parasound p/ld 2000 would be interesting as well but I’m intrigued by the Adcom.
BDT
    pitdogg2 Posts: 27,045
    edited May 2020
    hit up GlennDog Troy..
  • TroyD
    TroyD Posts: 13,124
    Just sent a PM....thanks!
    nooshinjohn Posts: 25,918
  • TroyD
    TroyD Posts: 13,124
    Looking for the preamp...but those are cool for sure...
    audioluvr Posts: 5,915
    What is a driver card? If this is in the signal path I'd be worried that "replaced with a modern equivalent" affects the sound that the original designer wanted. Plus ALL the electrolytics should have been replaced because "In spec" doesn't particularly mean "sounds good". But hey these are cool regardless!
    You should see if @treitz3 still has that Cary CPA-1 pre. That surely would be equivalent and in your price range.
  • BlueFox
    BlueFox Posts: 15,251
    TroyD wrote: »
    Try a Cambridge Audio 840E. That is the pre I had before the Pass, and it sounds great. Last year my Pass broke so I had to use my 840E in its place, and it was very close to the Pass.
    Viking64 Posts: 7,550
    audioluvr wrote: »
    They are probably referring to the optional printed circuit board for the balanced input that goes where the blank cover is on models without this feature.
