Air Core Inductor falls off crossover during shipping
13»
    VR3 Posts: 29,538
    If you use the quad I would twist the end, the Quadrax is not the best option for internal wiring due to its size
  • jdjohn
    jdjohn Posts: 3,380
    Oh, I see now. The first image of Rondo I saw was 2X2.5, but now I see there are several 4X options: 1.6, 2.5, 4.0. So with 4X, you twist in pairs to get +/-.
    pitdogg2 Posts: 27,242
    Well that green tarnish would be all I need to see to get rid of the wire there now, but I completely understand Drew's position.
  • jdjohn
    jdjohn Posts: 3,380
    I'm struggling to see...are the strands coated copper, or aluminum? They don't look like solid copper at first glance.
    mhardy6647 Posts: 35,203
    jdjohn wrote: »
    The former is due to residual HCl in the PVC insulation and is inevitable with zip cord like that.
    One would like to think it's 'pure' copper (if not OFC) and not CCA. Based on @clipdat's experience to date, the manufacturer would probably answer the question if asked.
    Clipdat Posts: 13,100
    jdjohn wrote: »
    Hey good eye, Jody. I took a closer look and took some pics. It looks like the negative lead/wire is silver colored and the positive one is copper colored. Not sure what that means, I'll ask ATC what type of internal wiring is used.
  • Gardenstater
    Gardenstater Posts: 4,802
    edited April 2020
    looks like good old fashioned speaker wire, where the insulation is clear and the negative wire is tinned copper stranded and the positive is bare copper stranded.
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
    The silver colored lead is (should be) tinned copper.
    So is that good or bad?
    Neither. :)
    It is a time-honored way of labeling wire for polarity -- the copper gets tinned when soldering, so no real net effect.
    Oh ok, interesting. I did appreciate that it's at least larger gauge internal wiring versus what I've seen used in other speakers.
    edited April 2020
    My stance is that it makes sense to either repair the stock wiring and inductor and leave it at that, or go hog wild for a full crossover upgrade. Either reusing the PCBs or going point to point wiring.
    If I did want to explore the possibility for a full upgrade, is there anyone here on the forum who would be willing to undertake this project if I pay them for it? I know we have some people here known for their meticulous crossover work and attention to detail like @westmassguy
    F1nut Posts: 51,954
    My 2 cents....you might want to establish a base line with everything original to see if the sound signature/performance is something you like before considering upgrades. I've never heard any of ATC's speakers, but from what I've read I don't want to.
    Yeah, fair enough. Point taken.
  • joecoulson
    joecoulson Posts: 4,943
    Clipdat wrote: »
    Sage advice, methinks -- it might be a different matter if they were 40 years old, but presumably they're relatively modern, so it's probably fair, and best, to hear them initially as their designers & builders intended.
    As a wino on a bus in Bermuda sagely opined to me one beautiful day years ago
    The largest room in the world is the room for improvement
    As my luck would have it even though I had FedEx box and pack the crossover to ship to Joe, the heavy inductor broke loose from the PCB again and moved around in transit. It destroyed the leads on several of the wonderful BENNIC capacitors, broke other wires off, and generally made a huge mess.
    Undeterred, Joe calmly fixed everything and got it working and tested - fully functional. Amazing! Big thanks to Joe for his help and going the extra mile.
    Looking forward to receiving it back and getting the speaker put back together!
    Clipdat wrote: »
    As my luck would have it even though I had FedEx box and pack the crossover to ship to Joe, the heavy inductor broke loose from the PCB again and moved around in transit. It destroyed the leads on several of the wonderful BENNIC capacitors...
    [emphasis added]
    Oh the humanity.
    B)
  • joecoulson
    My pleasure
    It’s packed up right, but still fingers crossed for a safe transit. Going with UPS as they seem to be the lesser of two evils.
    F1nut Posts: 51,954
    edited May 2020
    FedEx is absolutely the lesser of the two evils, hence the reason the L200 demo speakers are required to be shipped via them. I wouldn't trust UPS to safely ship a feather.
    Drew, you should always pack your own stuff. FedEx nor UPS have anything other than peanuts and bubble wrap to use for packing material of which neither is suitable for shipping hifi gear.
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,808
    Jesse, I agree with that. My brother and I shipped over 3000 antique clocks (wood, glass, movements, springs) of all sizes over a ten year period and UPS was danger - use only FedEx. And it's almost impossible to have an insurance claim paid by UPS.
    On Tuesday I received a portable air conditioner ordered from Amazon, and some of the parts were spilling out the bottom of the box. Shipped by UPS. The driver let the entire package roll off his hand trucks at my front door, but the major damage occurred in shipping probably by the automated belts that move the packages in the warehouse. One package stops and a larger one hits it.
    @Joe, I suggest you devise something that restricts movement of the parts and "cushions" the inductor. Devise something that keeps the momentum from sending it crashing. It's the inside of the box packing that you have to worry about.
    Harry
    Harry / Marietta GA
    Moved, seconded, and approved. FWIW.
    (also FWIW, my own track record with the good ol' USPS is extremely good, but then again the size and weight of things that are practically shippable by USPS is limited)
    Don't invite an @polkfarmboy moment.
    @hermitism maybe we need some sort of polkfarmboy badge to underscore packing and/or shipping mishaps (and/or discussions involving skinny jeans or Boxsters)?
  • mpitogo
    mpitogo Posts: 520
    Nice candidate for a crossover rebuild upgrade project. You weren’t expecting it but it could be cool.
    • Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
    • Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
    • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
    • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
    • Office-2.1 B&W Formation Duo and Bass
    • Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
    • Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
    • Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
    • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
    • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
    • Maintenance: Pro-Ject VC-S Record Cleaning Machine
    edited May 2020
    I agree, and 99% of the time I do pack my own shipments. Problem is that since I'm working from home I didn't have access to the boxes/packing materials I had at the office. Plus I was thrown off and nervous by the whole 6ft social distancing, masks, etc. and felt like I had to let them pack it and just assumed that as an employee of the FedEx Office company that they would have been trained on how to pack an item for safe transit. Clearly not. I even asked her after she packed it if it moved around in the box at all, and she lied and said no.
    But ultimately it's my fault. I made a stupid mistake that I won't be making again.
  • jdjohn
    jdjohn Posts: 3,380
    I don't buy-in to one carrier being better than another. I've sent several items via UPS over the last few weeks/months with no problem at all. If it is packed properly, there shouldn't be an issue. Do they really handle items that differently...on the trucks, in the hubs? I'm sure there are good and bad package handlers/drivers at both companies. My son has loaded and driven for both (currently with FedEx), and he's never mentioned any differences.
    Some of you probably know that local FedEx ground is basically out-sourced to local contractors who purchase routes like a franchise. I guess it's feasible to think these contractors might take better care since the contracts could be pulled if there is bad performance. But on the other hand, one could argue that UPS employees are more incentivized to perform well over the long haul in order to keep their benefits. Disgruntled FedEx drivers can (and do) jump ship to work for other local contractors all the time, so not quite as loyal as UPS drivers.
    In the end, I think it's a crap-shoot either way, and just depends on who handles the packages on any given day at any given location.
    VR3 Posts: 29,538
    For me ups is a huge pain in the rear. The local hub is open one hour a day for the public, yes, 1 hour, 5pm to 6pm. The ups stores are franchises and yiu have to pay 6 dollars to have a package rerouted there. Simply awful.
    Hate to hear they were redamage shut glad Joe got you hooked back up
