Random trivia
VR3
Random trivia
If you have a
1.5 inch sill plate
9.25 floor joist
3/4 inch subfloor
you have to tell your Mason how far below an existing structure he has to have the height of his wall. How much lower than the existing structure would you go to be flush.
A. 10.75"
B. 11.5"
C. 12.25"
D. 10"
If you have a
1.5 inch sill plate
9.25 floor joist
3/4 inch subfloor
A. 10.75"
B. 11.5"
C. 12.25"
D. 10"
How thick are the mortar joints, how tall will the wall be?
The top of the existing structure subfloor is the main measurement, we are just looking how much lower from the existing structure should the final masonry wall be so that the two subfloors are level.
The sill plate is 1.5", 9.25" floor joist, 3/4 subfloor
The masonry wall can be built and adjusted to accommodate this measurement- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
E is 11.625. you forgot this:
https://www.homedepot.com/p/Owens-Corning-FoamSealR-5-1-2-in-x-50-ft-Multi-Use-Ridged-Sill-Plate-Gasket-2FS/202080947Gustard X26 Pro DAC
Modular Brick at 2-1/4
Joint width at 3/8-ish
11-1/2” but you will go to the next full brick size unless you are cutting.
12-3/4”...Where’s the KABOOM?!?! There’s supposed to be an Earth shattering KABOOM!!! -
12-3/4”...
Yup. That's what we came up with. -
But Ah-ha! You all forgot to factor in for the height of the crushed 7/11 Big Gulp and hot dog box to be built over.I disabled signatures.
This doesn't seem very random to me.
Expert Moron Extraordinaire
There's back story obviously, but 11.5 appears to be the winner 🤔🤔🤔🤔- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
No joint at top. Just make it flush with the top of the block. Don't forget J - boltsGustard X26 Pro DAC
LOL, Trey. You gon'go cray-cray if this is yo' major hangup. Wait until next week when they say the roof height is lower than the ceiling height and that you are WRONG!
Have fun broski'!
Tom~ In search of accurate reproduction of music. Real sound is my reference and while perfection may not be attainable? If I chase it, I might just catch excellence. ~
