Random trivia
VR3
VR3 Posts: 29,573
Random trivia
If you have a
1.5 inch sill plate
9.25 floor joist
3/4 inch subfloor
you have to tell your Mason how far below an existing structure he has to have the height of his wall. How much lower than the existing structure would you go to be flush.
A. 10.75"
B. 11.5"
C. 12.25"
D. 10"
    pitdogg2 Posts: 27,425
    How thick are the mortar joints, how tall will the wall be?
    VR3 Posts: 29,573
    The top of the existing structure subfloor is the main measurement, we are just looking how much lower from the existing structure should the final masonry wall be so that the two subfloors are level.
    The sill plate is 1.5", 9.25" floor joist, 3/4 subfloor
    The masonry wall can be built and adjusted to accommodate this measurement
    msg Posts: 10,490
    Is it D?
  • mrbigbluelight
    mrbigbluelight Posts: 9,878
    It's E, All of the Above
    audioluvr Posts: 5,996
  • mrbiron
    mrbiron Posts: 5,721
    Modular Brick at 2-1/4
    Joint width at 3/8-ish
    11-1/2” but you will go to the next full brick size unless you are cutting.
    12-3/4”...
  • lightman1
    lightman1 Posts: 10,797
    mrbiron wrote: »
    12-3/4”...
    Yup. That's what we came up with.
    msg Posts: 10,490
    But Ah-ha! You all forgot to factor in for the height of the crushed 7/11 Big Gulp and hot dog box to be built over.
  • Jstas
    Jstas Posts: 14,997
    This doesn't seem very random to me.
    Expert Moron Extraordinaire
    VR3 Posts: 29,573
    There's back story obviously, but 11.5 appears to be the winner 🤔🤔🤔🤔
    edited April 2020
    No joint at top. Just make it flush with the top of the block. Don't forget J - bolts
    treitz3 Posts: 20,159
    LOL, Trey. You gon'go cray-cray if this is yo' major hangup. Wait until next week when they say the roof height is lower than the ceiling height and that you are WRONG!
    Have fun broski'!
