Polk out of RD0194!?!???
Joshwest90
Joshwest90 Posts: 109
edited April 2020 in Vintage Speakers
I called Polk today ready to bite the bullet on (4) RD0194 to finalize my upgrade for my sda-1a. The guy told me they are out of stock and referred me to Midwest speaker!!! This is terrible lol.
  • CH46E
    CH46E Posts: 3,595
    I think they have been for awhile now. They pop up here for sale every so often but go FAST! Set up and save a search on ebay so you get notifications when some are listed. Probably your best bet.
  • Joshwest90
    CH46E wrote: »
    There are 2 on eBay, but more expensive than what you used to be able to get them from Polk :(
    xschop Posts: 5,437
    Or you could drop in some aftermarket silks/domes on the cheap.
  • Joshwest90
    xschop wrote: »
    Don’t you have to modify the cabinets to run other tweeters? Has anyone done this with success? How do other tweeters work compared to the RD0194
    F1nut Posts: 52,042
    edited April 2020
    Do not drop in any other tweeter. There are very specific technical specifications that if not an exact match will result in less than ideal sound.
    I believe Polk will no longer sell the RD0194 and RD0198 tweeters. Midwest has taken over selling them. They are exactly the same tweeters.
    xschop Posts: 5,437
    edited April 2020
    I assumed you had the SL2000's and a few of us have modded them with aftermarket silks.
    If you can hold out for a good set of RD0194's, then by all means. If Polk never manufactures another set of them, then you'll be back to installing aftermarket silks, but much easier to do them to 194's
    And if you get them from Midwest, let us know if the plastic deforms and resonates like some of the originals do.
  • teekay0007
    teekay0007 Posts: 2,288
    Josh, you might also want to consider getting just two 194s and disconnecting the two SDA tweeters in your 1A’s. That seems to be preferred by those around here who have updated that model, IIRC.
  • Joshwest90
    teekay0007 wrote: »
    So just disconnect the inner tweeter on both speakers? I have redone the crossovers with updated caps and resistors. Was just waiting on the tweeters and now they are gone haha my luck.
  • Joshwest90
    I see Midwest has them, but they are 8-10.00 more than what I remember Polk selling them and doesn’t include free shipping. Do you agree with teekay to unplug the dimensional tweeter?
    pitdogg2 Posts: 27,400
    The inner tweeter is the stereo tweeter. The outer tweeters are the dimensional tweeters. Do your SDA1 have fuses ? If yes take out the fuse, if not then unhook the tweeter leads and tape so they do not touch and cause a short.
    F1nut Posts: 52,042
    edited April 2020
    The list price has always been $60.00. Club Polk members got a discount from Polk. Those days seem to be over.
    Yes, I agree. The dimensional tweeter(s) impart an unnatural phasey effect. You can try disconnecting them before ordering new ones to hear for yourself what it sounds like. Be sure to tape off and secure the leads.
  • Joshwest90
    These SDAs do not have the fuse on the back. Once I pull them I’ll shrink tube the leads to prevent shorting.
    Is this the case for the SDA-CRS as well
    @F1nut @pitdogg2
    F1nut Posts: 52,042
    For the original CRS with 2 tweeters? Yes.
  • Joshwest90
    Yea these have 2 tweeters. Well that’s good to know. Less RD0194 to buy haha
  • teekay0007
    If it were the single tweeter models he’d probably notice something missing in his music. :p
  • Joshwest90
    @F1nut are the SDA-2A the same as the SDA-1A and CRS in regards to disconnecting the dimensional tweeter?
    F1nut Posts: 52,042
    No, the 2A only has one tweeter.
  • crcolby
    crcolby Posts: 18
    FWIW, I ordered MW6511's (the mid/woof's) a couple of months back. The guy on the phone said I got 4 of the last 5 in stock.
  • Joshwest90 wrote: »
    Rd0194's just popped up on ebay.. but they are $60 each.. say there is more than 12 available
    F1nut Posts: 52,042
    $60.00 is the normal price and that's cheap compared to a lot of other tweeters out there.
  • gyosa
    gyosa Posts: 770
    So very true when you think about it ....
    Hard to believe they’re so inexpensive....
    The Raal tweeters in my Salks are 5-6 times that price ....
    Bk
    PS Audio S300 , WiiM Ultra , Yamaha wxc-50 , Salk SuperCharged Songtowers , Kimber Kable 4TC, Sony 48” - BEDROOM
    B&K EX-442 ( it will go in my casket when I die ... ) , PS Audio 4.6 preamp ( old school , but it still jams on ... ) , Eversolo DMP-A6 , Boston Acoustic voyager 7’s - POOL
    Parasound A21, Eversolo DMP-A8 , Kimber Kable 4vs , Ascend Acoustics ELX Ribbon Towers , Sony XBR-A8F 65” OLED - DEN , MAIN system
    Onkyo TX-nr609 , Polk atrium 7 , Boston acoustic sound ware (4) , Boston acoustic sub , B&W center , Sony 65” TV - PATIO
    gyosa wrote: »
    Bk
    they're also about 5-6 times better tweeters ;)
  • ratpin
    ratpin Posts: 99
    Any word on if/when polk will start selling these again?
    Polk: / SDA-CRS / SDA-1C / M-10B / M-7B / M-5 / M-5jr / RTA-11T / LSIM703 / LSIM704 / LSIM706 / RTI8 / CSI3 / CSI5 / RTI4 / RTI-A5 / CSI-A6 / RC80i / RC85i / RC6s / PSW300 / Atrium6 / Atrium4 / About a dozen pair of Atrium45 lol.
    nooshinjohn Posts: 26,016
    I would not be surprised to find out they are done supporting the vintage SDA line.
    F1nut Posts: 52,042
    edited June 2020
    It's already been stated that Polk's support for vintage Polk speakers is over. MidWest is taking over offering the tweeters and a one model fits all type driver, which it is not.
  • Jstas
    Jstas Posts: 14,997
    For anyone who is not sure what's being talked about, here is a link to Midwest Speaker Repair.
    https://www.midwestspeakerrepair.com/
    Here's the Polk Audio tweeter page:
    https://www.midwestspeakerrepair.com/product-category/home-audio/tweeters/polk-audio-1-tweeters/
    Expert Moron Extraordinaire
  • BlueBirdMusic
    BlueBirdMusic Posts: 2,876
    On June 3, I purchased four RD094's to have as backups from Polk . They came right away in 3-4 days. Got the discount and free shipping.
    There was hardly any wait for the first person to answer to handle the sale; and put the invoice together. Then the sales person hands you off to a financial person to collect the money. I waited for about an hour to pay. No RD098's on that day.
    The two people were really good at their job. Nice and knowledgeable.
    Harry
    Harry / Marietta GA
    That's just the way it is ~ Some things'll never change ~ That's just the way it is
    Ah, but don't you believe them
    Bruce Hornsby
  • cutiger
    cutiger Posts: 8
    Just ordered 2 from The Speaker Exchange in Florida......arrived in 2 days.
  • VSAT88
    VSAT88 Posts: 1,341
    ^ Sad...
    xschop Posts: 5,437
    Better start researching which Peerless is closest to the original RDOs. I believe Polk used Peerless as the magnet/bezel have the exact same bolt patterns.
