Where do you order your media from?
CH46E
CH46E Posts: 3,595
edited April 2020 in Music & Movies
Looking to buy several albums on disc, SACD/HDCD/CD/DVD-Audio and such.
Can you guys give some suggestions to reputable mail order retailers??
Acoustic Sounds and Music Direct were a few I was looking into.
Thanks!
  • CH46E
    CH46E Posts: 3,595
    I'd also be intrested in DSD and FLAC downloads were I can pick and choose what songs I want to buy.
  • Nightfall
    Nightfall Posts: 10,084
    edited April 2020
    Check out Discogs. You can choose what you want down to the specific pressing, region, that rare copy that has a barcode on the back when most don't type thing.
    afterburnt wrote: »
    Village Idiot of Club Polk
    pitdogg2 Posts: 27,051
    I buy most of mine on ebay new and used.
  • CH46E
    CH46E Posts: 3,595
    I finally found out how to play DSD and FLAC 24 bit 192khz from a thumb drive via USB port on my Yamaha Aventage HTR.
    I also found Qobus that allows me to download single tracks in FLAC.
    Discogs looks to be very good source for specialty albums. Thanks!
  • Hermitism
    Hermitism Posts: 4,329
    For single track FLAC I also use Qobuz and also 7Digital. Check both and compare prices. Sometimes one is cheaper, other times the other is cheaper. Depends on the album.
  • CH46E
    CH46E Posts: 3,595
    These are straight files right? Dont need any proprietary software to listen to them? I head Tidal makes one use MQ.. something or another which wont work for my Yammy through the usb.
    Thanks for the 7digital. I'll take a look now.
  • BlueFox
    BlueFox Posts: 15,251
    Buying CDs is with Amazon. Most new music is an HDTracks download.
  • Hermitism
    CH46E wrote: »
    Yes, just normal flac. My preferred method is to load them up on a thumb drive and plug it straight into my Marantz Network player/DAC. It has no issues playing them. My computer plays them without issue, also. In case you're not used to it, after purchase you select which format for download. Flac isn't selected by default. Don't forget to download the album art, as well. It's offered on both sites. I found that most digital download sites don't offer single track downloads, just full albums. But I've had good luck with Qobuz and 7Digital.
    I usually buy full albums used off of eBay. But for those albums with one good song and the rest being turds, I just download single tracks.
    gudnoyez Posts: 8,161
    Mofi, CD Japan, Bullmoose to name a few.
  • tophatjohnny
    tophatjohnny Posts: 4,189
    Yes Discogs . I look there first but recently found a rare jazz rock CD on eBay for a lot better price than was listed on Discogs. I take a beating every time I buy a CD as I usually end up selling it for half of what I paid for it.
    Recently sold $1500.00 worth of CDs on Craig's list for $700.00. Crazy stuff
  • CH46E
    CH46E Posts: 3,595
    edited April 2020
    Thanks guys. I picked up the Tool Inoculum album in 24 bit FLAC as well as 13 other individual tracks from Qubuz. So far I'm very happy with the service they provide.
    Tool's toms hit hard and the highs sparkle. Very clean recording.
    I notice right away playing from the USB drive the sound floor is zero. Imaging for a Dennis Lloyd song I played was scary good. I actually had to check that my center channel was not playing.
    Mozart Requiem In D minor gave me goose bumps. You could feel the violin!
    Remember, I've been using Pandora and YouTube for 85% or more of my music. So these FLAC files are a treat.
  • Ape22
    Ape22 Posts: 9
    We have upgraded and on online apps now including YouTube. Don't remember the last time using a CD or DVD. It's been a long time.
    An Audiophile Plugged Into Nirvana
