Billet Grill Pegs
xschop
Working out a 1-piece indestructible design.
I've seen other posts calling these "sphere"
ands that's what my 5bs have.
Nice
I should be able to tap inside cabs without adding glue....
Don't take experimental gene therapies from known eugenicists. -
6 more to go....
Looking good!Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
Polk SDA2btl highly modded
Polk SDA 1C modded
Polk CS350 LS x2
Kimber 8TC
Sony 55" Bravia
Wish list SVS sub -
Hey thanks Randy, how are those SDAs coming along?
A little preview, I will be making multiple RD0194/8 billet tweeter plates soon with proper throats and rear magnet recesses....
Remember @xschop folks had to put a #10 washer under the hole to make sure the plate was not pulled down too much it may be prudent to get hands on an older SL2000 face plate to match the stand off they had on the rear. Maybe a sl2500 and sl3000 faceplate to also see how different there are to the 194/198 and go from there.
I do have some sacrificed sl2000 plates i could send.
Before these go full throttle ahead.
I could be interested in some. -
If they work out well, I would be up for a set myself...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
I remember that issue. It was due to the flimsy plastic buckling correct?
I plan on making them with the exact tolerances of the RD0194 plates I have here. I guarantee they wont buckle when bolted down.
The other aspect of the washer mod is that not everyone reported actual cabinet tweeter routing depths to warrant adding to a re- machined plate?Don't take experimental gene therapies from known eugenicists. -
Yes flex did come into play as well as the back corners under the screws were not as tall or even with the rest of the face plate as seen here. The washer made up the difference.
Sl 3000 notice the back is supported around the screw hole even with front bezel.
RD0198 notice the screw hole is much lower than bezel allowing the screw to pull it down more than those supported.
Yes older tweeters were much more rigid faceplate.
Ah ok. So as long as the new plates are the same thickness thru the baffle mount holes as the outer edges, no need for washers underneath?Don't take experimental gene therapies from known eugenicists.
Correct
Thanks for clarifying. If I didn't post something within the week, I can't find it lol.
IIRC, the SL-2000's had a different tweeter magnet mount dimension as well?Don't take experimental gene therapies from known eugenicists. -
SL2000 dome and voice coil was glued to the front bezel if that is what you mean, you can see in my first pictures.
I meant the 4 magnet-to-plastic plate mounting hole spreadwidths.Don't take experimental gene therapies from known eugenicists.
Ok could be. I have not measured them. -
I would be concerned about using hard metal for a tweeter bezel. IMO, it is bound to make the highs harsher/brighter.Political Correctness'.........defined
President of Club Polk -
Have you tried a set?
Looks awesome anyway.Stan
Main 2ch:
HT:
Other stuff:
Hit it on first try....
Any chance of making a few more of those peg sets?The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
Yes, I would need some exact hole diameters in your cabs and grill frames.Don't take experimental gene therapies from known eugenicists.
Of course not. Take a look around at all the speakers on the market and besides horns and wave guides you won't find many with metal tweeter bezels.Political Correctness'.........defined
Come on live a little. Take a look 8 posts above.... Toolfan approved hehe.Don't take experimental gene therapies from known eugenicists.
Do you sleep? Hmmhmm
I bet next you'll tell me my phase plugs don't clean up the mids.Don't take experimental gene therapies from known eugenicists. -
Yeah, I remember when he made them. I didn't like the idea then either.Political Correctness'.........defined
No idea about those, never bothered to research it.
Forgot to answer....yes, about 8 hours straight though.Political Correctness'.........defined
PM mhardy, he'll school you on them... Great guy and knowledgeable too.
Only been listening to them for about an hour now... Indeed cleans up the Oboe and baritones.
I'm going to hibernate. Plenty more listening to do tomorrow.
I'll look forward to your further impressions.Political Correctness'.........defined
Anyone else able to measure their grill frame holes to confirm 0.305" diameter on all 4 corners?Don't take experimental gene therapies from known eugenicists.
