Billet Grill Pegs
Working out a 1-piece indestructible design.
I've seen other posts calling these "sphere"
    xschop Posts: 5,484
    I should be able to tap inside cabs without adding glue....
    xschop Posts: 5,484
    6 more to go....
  • Looking good!
    Yamaha RXA1030, Yamaha CD-S2100, Yamaha AS-2200, Bluesound node 2i
    Polk SDA2btl highly modded
    Polk SDA 1C modded
    Polk CS350 LS x2
    Kimber 8TC
    Sony 55" Bravia
    Wish list SVS sub
    xschop Posts: 5,484
    Hey thanks Randy, how are those SDAs coming along?
    A little preview, I will be making multiple RD0194/8 billet tweeter plates soon with proper throats and rear magnet recesses....
    pitdogg2 Posts: 27,438
    edited March 2020
    Remember @xschop folks had to put a #10 washer under the hole to make sure the plate was not pulled down too much it may be prudent to get hands on an older SL2000 face plate to match the stand off they had on the rear. Maybe a sl2500 and sl3000 faceplate to also see how different there are to the 194/198 and go from there.
    I do have some sacrificed sl2000 plates i could send.
    Before these go full throttle ahead.
    I could be interested in some.
    nooshinjohn Posts: 26,021
    If they work out well, I would be up for a set myself...
    xschop Posts: 5,484
    I remember that issue. It was due to the flimsy plastic buckling correct?
    I plan on making them with the exact tolerances of the RD0194 plates I have here. I guarantee they wont buckle when bolted down.
    The other aspect of the washer mod is that not everyone reported actual cabinet tweeter routing depths to warrant adding to a re- machined plate?
    Yes flex did come into play as well as the back corners under the screws were not as tall or even with the rest of the face plate as seen here. The washer made up the difference.
    Sl 3000 notice the back is supported around the screw hole even with front bezel.
    RD0198 notice the screw hole is much lower than bezel allowing the screw to pull it down more than those supported.
    Yes older tweeters were much more rigid faceplate.
    xschop Posts: 5,484
    Ah ok. So as long as the new plates are the same thickness thru the baffle mount holes as the outer edges, no need for washers underneath?
    xschop Posts: 5,484
    Thanks for clarifying. If I didn't post something within the week, I can't find it lol.
    IIRC, the SL-2000's had a different tweeter magnet mount dimension as well?
    edited March 2020
    SL2000 dome and voice coil was glued to the front bezel if that is what you mean, you can see in my first pictures.
    xschop Posts: 5,484
    I meant the 4 magnet-to-plastic plate mounting hole spreadwidths.
    xschop wrote: »
    Ok could be. I have not measured them.
    F1nut Posts: 52,052
    I would be concerned about using hard metal for a tweeter bezel. IMO, it is bound to make the highs harsher/brighter.
    xschop Posts: 5,484
    Have you tried a set?
  • skrol
    skrol Posts: 3,472
    Looks awesome anyway.
    Stan
    Main 2ch:
    HT:
    Other stuff:
    xschop Posts: 5,484
    Hit it on first try....
    Any chance of making a few more of those peg sets?
    xschop Posts: 5,484
    Yes, I would need some exact hole diameters in your cabs and grill frames.
    F1nut Posts: 52,052
    xschop wrote: »
    Of course not. Take a look around at all the speakers on the market and besides horns and wave guides you won't find many with metal tweeter bezels.
    xschop Posts: 5,484
    Come on live a little. Take a look 8 posts above.... Toolfan approved hehe.
    xschop Posts: 5,484
    edited March 2020
    Do you sleep? Hmmhmm
    I bet next you'll tell me my phase plugs don't clean up the mids.
    F1nut Posts: 52,052
    Yeah, I remember when he made them. I didn't like the idea then either.
    F1nut Posts: 52,052
    edited March 2020
    xschop wrote: »
    No idea about those, never bothered to research it.
    Forgot to answer....yes, about 8 hours straight though.
    xschop Posts: 5,484
    edited March 2020
    xschop wrote: »
    PM mhardy, he'll school you on them... Great guy and knowledgeable too.
    Only been listening to them for about an hour now... Indeed cleans up the Oboe and baritones.
    I'm going to hibernate. Plenty more listening to do tomorrow.
    F1nut Posts: 52,052
    I'll look forward to your further impressions.
    xschop Posts: 5,484
    Anyone else able to measure their grill frame holes to confirm 0.305" diameter on all 4 corners?
