Repair for Polk stands
Al_Swearengen
What’s best for getting the vinyl back down on the base to these Polk stands? Anybody? Thanks.
FKA: anton.chigurh (see profile page)
I'd try contact cement.
Yep apply to both parts let dry and push together. You get one try to get it right good luck
Superglue?Main System 2.2:
Proton AA-1150 ~ Yamaha C-4 ~ Furman Elite-15 DMi ~ Sennheiser HD600 ~ Monitor Audio Silver RS8
(2x) Martin Logan Dynamo ~ Marantz CD5003 ~ Squeezebox Classic ~ Music Hall dac25.2 ~ Sansui D-X111R
Dual 1229/Acutex M312 III STR ~ Music Hall mmf-5.1/Goldring 1012GX ~ Music Hall Cruise Control 2.0
Home Theater 5.2:
Yamaha RX-V800 ~ Furman Elite-15 DMi ~ Polk Audio RT55i ~ RT35i ~ CS400i ~ (2x) PSW450
Winter Residence 2.1 (laptop system):
Yamaha RX-485 ~ Squeezebox Classic ~ Topping D30 ~ EPI M90 ~ Dayton Audio SUB-1200 -
classic carl wrote: »Superglue?
no it will fail. -
Thanks for the contact cement suggestions.FKA: anton.chigurh (see profile page)
I've used wood glue on some veneers. Both real wood and vinyl. Only trouble is that You have to set it on its side and put weight on it. Not too big a deal, but kinda annoying for something thin like that.
Next time I'll try contact cement.
Good luck with the repair! -
Went to the hardware store today and finally remembered to grab some contact cement. Made the repair and it appears to have worked nicely.FKA: anton.chigurh (see profile page)
NMPolitical Correctness'.........defined
