Tube supplier and cross reference thread
treitz3
I have recently updated my list of tube suppliers and other tube related websites that I have gathered over the years and figured I'd share it with all of you. Just so you know, I have no affiliation with any link provided. Happy hunting!
http://www.tubeaudiostore.com
http://www.emissionlabs.com
http://www.jacmusic.com
http://www.vacuumtubes.net/
http://www.kcanostubes.com/
http://www.dougstubes.com/
http://www.vacuum-tube-shop.com/
https://www.watfordvalves.com
http://www.natubes.com
http://www.shuguangtube.com/
http://www.mafaudio.com/pro/propage.aspx
http://www.jjyaudio.com/products.asp?menuid=161&menuid1=255
http://www.brimartubes.com/
brentjes@audiotubes.com
http://www.tubemonger.com/
http://www.cryoset.com/
http://tctubes.com/
www.analogtubes.com
http://www.tubedepot.com/
http://www.thetubestore.com/
http://www.tubemuseum.org/
http://www.triodeelectronics.com/
http://www.electron-tubes.com/
http://www.house-of-tubes.com/home/hot_home.asp
https://www.tubeworld.com/index_high.htm
http://www.starkelectronic.com/tubes.htm
http://www.tube-shop.com/
http://www.mullardtubes.com/
http://psvanetube.com/wordpress/
http://www.upscaleaudio.com/
http://www.vacuumtube.com/
http://www.valves.uk.com/ [UK site]
http://www.vacuumtubesinc.com/
http://www.vacuumtubes.com/price7.html
http://www.r-vac.com/tubes.htm
http://www.tubedata.org/
http://stores.ebay.ca/SaleRCS
http://www.vac-amps.com/homepage.htm
http://members.aol.com/etetubes/
http://www.audioasylum.com/scripts/d.pl?audio/faq/joes-tubes.html
http://www.audiotubes.com/
http://radiodaze.com/
http://hktubeaudio.homestead.com/files/tubecode.html
http://www.musicdirect.com/
http://classic-tubeshop-kunisch.de *You can email Annette Kunisch in English.
http://www.tube-and-valve-electronics.co.uk/
http://www.mcshanedesign.net
http://www.partsconnexion.com/ Scroll down for preference
http://tubemaze.info/
http://www.hifitubes.nl/catalog/tubes-c-21.html
http://www.chelmervalve.com/
And tube tweak links
http://herbiesaudiolab.net/
http://www.thetubestore.com/tuberings.html
http://www.vintagetubeservices.com/Dampers.htm
http://www.jenalabs.com/ [Tube Cryo-ing service - JenaLabs]
http://tubeman.com/ [Tube Cryo-ing service]
http://www.elusivedisc.com/prodinfo.asp?number=MHEATDAMP
Tube Guide - http://hktubeaudio.homestead.com/files/tubecode.html
Weird tube numbers/letters - http://pax-comm.com/rcadates.pdf
Date codes for RCA - http://mysite.verizon.net/tubetronic/PDF_FILES/RCA DATE CODES.pdf [RCA date codes]
Quick reference to Amperex, Mullard, Philips, and Valvo Tube Codes - http://www.audiotubes.com/mullcode.htm
Foreign substitutes list for American type tubes [research thoroughly before any tube purchase!!!] - http://www.tubedata.info/usa2for.html
Feel free to add any tube supplier or tube information website you have ran across that might help someone else find what they might be looking for. Thanks and have a good day!
http://tctubes.com/
www.analogtubes.com
This one above blacked by both Malware bytes and McAffe for TROJANS proceed with caution if you must visit.
this one dead link. ^^Post edited by pitdogg2 on -
Thanks Tom..
Bookmarked to "My Favorites List" for quick references.
Thanks for the research, time, and posting.
Thanks Tom!AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Power Rogue M180 Dark monos
Mains Salk HT2-TL
Rythmik F12 -
Nice reference. Bookmarked. Thanks.➀Speakers: Polk1.2tl's (Uber Mods) ➁Pre/Amp/DAC: PS Audio PMG Signature Pre, BHK Signature 250, PMG Signature 512 ➂Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" ➃Power Conditioner: PS Audio P15 Power Plant ➄Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends ➅Streaming: Roon ROCK on wifi'd NUC, TP-Link WAP, & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
This needs to be a stickie. Nice work. Thank you sir.2-channel Yaqin B2-T Pre, Emotiva XPA-2 Gen 2, Marantz SA8005, Pro-Ject RPM-10 Turntable, Denon DP-19L Pro-Ject Phono Box DS3B, Polk Audio Legend L800's, AudioQuest Cable throughout.
Does anyone have a recommendation for getting tubes tested?
I see that tctubes offers this service but I have never dealt with them.After being out of the game for 4 years I now look at a hodgepodge of tubes that I once knew what was what and now I’m having to start over.Any suggestions on a trusted source is appreciated.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
A trusted source to test tubes you already have?
How's it going Mike? -
Yes sir.Im trying to clean up the stock I have that I lost track of during my sabbatical.Find out what’s good/bad/weak/strong.
As they say,use it or lose it.I am digging into all these boxes and boxes of parts and spares that SOMEBODY bought and put in my basement.
I know most if not all are good but how good I no longer remember.
I’M OFFENDED!!!! -
Well I know a few here have tube tester's. Hopefully they chime in.
Nice to see you back man
Thanks.
I have looked for a tester but not worth the money not knowing what I will get.
Besides I am not planning much tube rolling for now.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
So -- the thing about tube testers is that -- to do it right, one needs a good transconductance type tester that is properly calibrated. That's actually a pretty high (read: expensive) bar, which is why I use a serviceperson grade emissions tester (Sencore Mighty-Mite) which will answer basic good/bad questions (emissions, grid leakage, shorts, and, with a tad bit of finagling, a "life" test) -- but cannot tell one anything about the actual in circuit performance of any tube, nor can it match tubes.
As in most things in life: ya gets what yez pays for.
I'd actually love to have something like a Hikok TV-7, but to find a good one that's rehabbed, calibrated and ready to go isn't a trivial quest.
The cool thing about my little Sencore? It was my father's daily driver in his TV repairperson days.
The ol' girl's got some miles on her.
DSC_7526 (2) by Mark Hardy, on Flickr
PS The best test of a tube is always
the in-circuit use test.
Yep i looked at the Hickok and as you say even if I get one that LOOKS good it doesn’t mean it’s calibrated to work correctly and that’s not a rabbit hole I plan to venture down.
I looked at the orange but don’t know enough to be confident it can do what I have.
KT120,6sn7,5ar,12ax and au,etc.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
jeepers, and I do even know how to spell Hickok correctly. I just can't type for...well, you know...
Sorry! Yeah, as @brgman typed it. Hickok. Hickok.
It would be nice to have a good tube tester and a curve tracer.
@brgman - what is your goal with the tubes you have? Make sure they are good or dead? I have a couple of testers. Nothing high end or fancy. One is a Sencore Mighty Mite. Don't recall the other one I have. Too lazy to go look. That being said, if you want to send me your tubes, I would be happy to test them for you. Bruce
Bruce I have a possible tester that is fairly local but if that doesn’t pan out I will contact you.
I very much appreciate the offer.
Yes it’s just to see what’s good or bad,strong or weak so I can eliminate the bad and replace them.I like to have at least one complete set of strong spares on hand.Main Rig-Realistic AM/FM Record player 8 track boasting 4 WPC
I’M OFFENDED!!!! -
His Mighty Mite would allow you to do that with (EDIT) "modern" tube types* -- besides emission and shorts, it's actually quite good for grid leakage, especially.. A long incubation can even "out" a weak output tube, the grid leakage will start very low & drift upwards as the tube warms up.
Plus they're supremely easy to use (although still a bit of careful knob-twistin' effort required with multi-section tubes like the 12A*7 twin triodes or, heaven forefend, Compactrons!)
_________________
* No four pin sockets, or old school 5, 6, or 7 pin sockets on any Mighty Mite morph I'm aware of to check old radio/audio tubes -- e.g., 45, 2A3, 300B, 76... that kind of thing.
So, ladies (Russ) and gentlemen....
Just following up here. If anyone has any new tube supplier or tube related source (informative or otherwise)?
Please post it here. I am STILL keeping a master list, updating, blah, blah, blah.
I'll give it a week or three and post the latest and greatest. Thanks all. Every tidbit of information may help someone you may not know (or do know) out with tube related gear/stuff.
"Vintage Tube Services – Tubes you can trust! Providing vintage audio tubes (new old stock) to audiophiles around the world. Celebrating 28 years of technical knowledge, experience, expertise, and tubes you can trust. For a free phone consultation call 616.454.3467." http://vintagetubeservices.com
Nice vintage tube link !!
This guy is about 25 minutes from my house
Problem is most Russian tube "equivalents" have a different pin out and you must rewire the product to use them. Kind of makes rolling tubes much more difficult. -
True. Hence my disclaimer.
But a 6П3С-Е or a 6P14P-EB from a good source at decent prices are nice.
And there's no pinout issue on those.
Again. As long as you know them.
When I click on this, all I get is some pharmacy prescription link. So, I looked it up manually....same thing. One every link I tried to access, I get an ED site or a pharmacy site.
I clicked on the link as well just minutes after it was posted and it went to the proper location.
Andy’s site has been hijacked and I will call him and let him know
I posted before about Vintage Tube Services… Andy’s a phenomenal resource
ty TomAC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12 -
It has been hijacked, but the site is only to reference tubes, I wouldn't order from the site as Andy is old school and will get your order out with a phone call. That's actually the only way to really order from him.
I just spoke to him. He’s been having problems for about the last 10 days . . . says his IT guy fixes it and some knuckleheads in Cyprus take it back down…
FWIW, He’ll be getting some Amperex 5AR4s in about a month.
I’ll be checking back in with him to see what this barn find brings 😎AC Regenerator PS Audio PerfectWave Power Plant 10
Pre Cary SLP-05
Mains Salk HT2-TL
Rythmik F12
