Matte finish a new paint trend for cars?
Yeah if they made vehicles with sheet metal the thickness of an 1840s railroad trestle. -
Flat paint jobs first became a thing when the police started using laser assisted radar guns to clock speeders because the laser guns had an "instant on" so you had no warning that a speed trap was ahead using a radar detector. Those and making radar detector use illegal pretty much killed the detector market. Some people figured out if they used flat paint on everything except the glass would render these guns ineffective. Eventually the radar manufacturers made a dual use radar/laser gun but by then the detectors for the masses were out of use.
The flat paint doesn't prevent you from getting a ticket though because the police can just say " Son, I don't know how fast you were going but I'm giving you a ticket anyways" and in court they would say " Based on the fact you were passing two cars, traveling at 55 miles per hour, that were fifty feet apart in approximately 3 seconds we calculated your actual speed at..."
Don't ask me how I know.
Now I would go for this paint job if the vehicle were similarly equipped, you wouldn't much have to worry about tickets.
It already is... the color is called” barn-find bronze”The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton/Typhon Rotel RP9400 Turntable
I'm not digging the matte finish either! Love the shiny top coats, freshly waxed, slippery to the touch. But then again, I'm a chrome guy too! Had to special order chrome bumpers on my truck, as the stock finish was painted.
In some cases, the matte finish can actually be molded into the material. Cost savings if done correctly. Hard to do on big body panels, but the smaller bits can usually be molded in color.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
Saw it on a Tesla today... not digging it myself.
― Aleksandr Solzhenitsyn
