SDA 1 pin style interconnect cable wanted
jtomasino
Many years ago I bought a pair of SDA 1 speakers from a friend. Unfortunately he had lost the interconnect cable. I have the pin style connectors. Does anyone have a cable they would like to sell or instructions on how I can build my own.
Answers
Thx...
That looks odd to me. Is it the original connector?Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
yes... its original.
Ok, @F1nut can you help??Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
All I can say is both speakers have this type of connector and my friend had purchased the speaker new.
Can you take another photo from further back showing more of the speaker?Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Did the 2 pictures get posted.
Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
Correct first SDA used a same input as the RTA12. The RTA 12 used it to connect top section to lower.
Very slim to none odds to getting an original cable. I'd start looking at the speakon connection we SDA folks have been using. -
It's original SDA1 with front port holes. -
Ok... thx for all the responses. I will look into the speakon connectors as you suggested.
I have never seen them before.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
Sunfire CG 200 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
These speakers may be from their original or very early days. They still sound great but want all drivers working.
https://www.neutrik.com/en/product/nl4fx
https://www.neutrik.com/en/product/nl4mp-uc
Got it... thx
Be very careful wiring that cable if you make one. If I remember right the wires don't go like the other pin/blade cables. I think they switch in the cable itself instead of inside the cabinet. I almost lost a Adcom 555 wiring it wrong.2 Channel
Polk 1.2tl's Modded with dreadnought
Musical Fidelity M6Si
North Star Intenso Dac
Auralic Aries Mini Streamer
Oppo 103
Pangea PC
Wireworld Equinox 7 interconnects
Wireworld Equinox 7 Speaker Cables and Jumpers
Backups 2.3tl, Crs+ pin/blade with stands.Monitor 5 peerless,Polk R200,McCormack Dna 0.5 Deluxe McCormack Dna 1,Dared Sl 2000A,Dayens Ampino,Rogue Magnum 66 pre -
Wire it just like the cabinet wiring. the wiring DOES switch pins inside cabinet. MAKE the cable positive to positive and negative to negative and do the switch at the speaker end. TAKE PICTURES of the wire placement BEFORE YOU EVER TAKE ANYTHING APART.
Will do...
President of Club Polk -
pitdogg2, thanks for your input on this (I have the same very early SDA 1 and would also like to connect them), but I did not quite understand your wiring instructions. Are you saying that the left pin on the left speaker interconnect does or does not have continuity with the left pin on the right speaker interconnect? -
Open it up and look. If the large blade on the speaker end is white the small blade on the right speaker should be white
Thanks pitdogg2, it is about time that I took a peak inside the cabinets. I had been on this track (https://forum.polkaudio.com/discussion/63792/questions-about-sda-1-speakers) and found seemingly compatible plugs and connectors, but they also left the polarity issue unresolved and I didn't know which route to pursue.
Fixed itOpen it up and look. If the large blade on the left speaker end is white wire the small blade on the right speaker should be white wire
I would think the pins are wired the same. I've never dealt with them.
Now wires of course could be a different color than white but hopefully you understand.
The nice folks at Polk support said that I just need a basic 3 pin XLR cable (1 of the pins is not needed) to connect these first generation (pin/pin) SDA 1 speakers. Thus, I ordered a Male-Female XLR cable and an adapter plug that has 2 female ends. Hopefully this will be $20 well spent and I can finally experience what SDA is all about. I hope to post results when the cable and adapter arrive.
Neutrik SpeakOn connectors would have cost even less and are vastly superior in every way.Political Correctness'.........defined
Thank you F1nut, I appreciate the feedback. I will look into the SpeakOn connectors for round 2 of my exploration into getting everything I can out of these great speakers. Hopefully the XLR cable will provide a first taste of the SDA and I will go from there.
@nanook52 , i recognize this post is 2+ years old now.
Did an XLR or SpeakOn cable resolve the issue for you?
I am looking at the pair of Polk SDA 1 speakers having the same interconnect cable jacks (2 pin) as pictured at the beginning of this post. As is common, the cable is missing at this time.
Cheers. -
Air tight SpeakOn sockets work beautifully.Political Correctness'.........defined
