new grills
eaadams
Is there anyway to get or make new grill covers with a different color than that awefull black. I was thinking of trying to make some that are silver to better match my WEGA.
Post edited by RyanC_Masimo on
This is a tough one. You can't really paint the fabric grilles, even spray paint will look like... Paint on fabric.
Maybe someone here will have some ideas (they're full of em, sometimes they even have something to do with the thread topic!), but I tend to think that you may be stuck with black fabric grilles.
Any takers?
MC -
....dye.....
Might cause the fabric to breakdown though.....
Cheers,
Hi:
You used to be able to buy spray paint for car upholstery at auto parts stores. It was made for fabric and did not have the build up normal spray paint has. Try that.
Gary:o -
You might be able to get an upholstery shop or something like that to make them......
However, I think that a poorly done job is going to look worse than what you have now. I kind of like the contrast, seems to work for the Raiders.....
Al DavisI plan for the future. - F1Nut
