Cary SLP-05 in Verb's House!
1234689
  • verb
    verb Posts: 9,925
    Whoa! :)
  • WagnerRC
    WagnerRC Posts: 2,014
    He started off asking $750.00
  • Joey_V
    Joey_V Posts: 7,672
    Sold?
    Now i definitely can’t let mine go
    Joey's Gear:
    Current Gear:
    Primary:
    Digital: Torus RM15 -> Emm Labs TSDx/Bluesound Node 2 -> Emm Labs DAC2x
    Analog: VPI Avenger Reference w/ Rim Drive w/ ADS + 12" Fatboy Dual Pivot + Lyra Etna
    + Audio Research Reference 40th Anniversary -> Boulder 2060 stereo amp (w/ Audioquest WEL Signature) -> new speakers + JL Audio F113v2 x2
    Secondary:
    Rotel RA1592 Super Integrated -> Sonus Faber Olympica 3
    Tertiary:
    Oppo 105D -> Rotel RC1570 preamp -> Rotel RB1582 amp -> Focal Kanta 2
    Main speakers system evolution over the years:
    Klipsch Promedia 4.1 -> Axiom M22ti -> Sonus Faber Concertino -> Sonus Faber Concerto -> Polk LSi7 -> Polk LSi9 -> Martin Logan Mosaic -> AV123 Onix Ref 1 -> Martin Logan Vantage -> AV123 Strata Mini -> Martin Logan Summit -> Sonus Faber Cremona Auditor -> BW 802D2 -> Sonus Faber Stradivari -> Rockport Avior -> BW 802D3 -> BW 800D3 -> ???
    Old Gear:
    Speakers:
    BW PM1 (3.5/5), CM10s2 (3.75/5), BW800D3 (5/5), Rockport Aviors (5/5), Sonus Faber Stradivari (5/5), BW 802D2 (4.5/5), Martin Logan Summits (4.25/5), Martin Logan Vantage (4/5), Sonus Faber Cremona Auditor (3.75/5), AV123 Strata Mini (3.5/5), ML Mosaic (3.25/5), Onix Ref1 (3/5), Sonus Faber Concerto (2.75/5), SF Concertino (2.5/5), Axiom M22ti (2/5), Polk LSi9 (3/5), LSi7 (2.9/5)
    Source:
    Squeezebox 3 -> PS Audio Digital Link III -> Cary 306/200 CDP -> Cary 306 SACD -> EMM LABS DAC2X/TSDX
    Preamplification:
    Rotel RC1070 -> Rogue Perseus -> Cary SLP98 -> Cary SLP98F1 -> Cary SLP05 (sold and then repurchased) -> ARC 5se -> ARC Ref 40th Anniversary
    Amplification:
    HK AVR330 -> Rotel RB1070 -> Rotel RB1090 -> Plinius SA102 -> Cary 211FE -> Classe M600 -> Boulder 2060
    Subwoofer:
    Infinity Entra2 -> SVS 25-31PCi -> SVS 25-31PC+ -> Dual JL Audio F113v2
    SCompRacer Posts: 7,227
    edited October 2019
    verb wrote: »
    Picked up another rectifier tube, as lessons learned, always good to have a spare! :)
    While slightly off topic, here is a shot I took of a 5Y3GT rectifier at work. It was in a DIY Hagerman Coronet 2 phono pre I built for a friend. It was upside down as I was checking voltages. Never looked at one like that before...
    Make yourself necessary to someone. Ralph Waldo Emerson
    Salk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ & Pro 11+ * Signature Series Sonore Music Server w/Deux PS* Twisted Pear Buffalo IIISE Pro ES9038 DAC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 *
  • GlennDog
    GlennDog Posts: 2,431
    WagnerRC wrote: »
    Apparently, these have sold. Have you added them to your stable?
    Power Rogue M180 monos & Adcom GFA 5802
    PS Audio PerfectWave Power Plant 10
    Rears Salk SuperCharged Surrounds
    Source PSA PWT into NSD Supremo
    Pre/Pro Integra DHC 40.1
    LCD Samsung LN46B750
    Mains Salk HT2-TL
    Center Salk HT2C
    Pre Cary SLP-05
    Wires WW & MIT
  • WagnerRC
    GlennDog wrote: »
    WagnerRC wrote: »
    Yes I did. I made an offer in line with what I paid on ebay and he accepted it. I really like the sound of the pope tubes, really like.
    I am now just one short.
  • GlennDog
    edited October 2019
    WagnerRC wrote: »
    Congratulations on your latest acquisition!
    AFAIK, you don’t need to run a full complement of Popes in all 8 or even 6 of the positions
    If you’re using XLR out of the Cary, just put the premium tubes in position #3 & 6
    If you’re using RCA, premium tubes go in position #1, 2, 4 and 5
    I don’t have cans yet, so I relegate EH tubes to #7 & 8
    Mains Salk HT2-TL
    Center Salk HT2C
    Pre Cary SLP-05
    Wires WW & MIT
  • WagnerRC
    Right now I am using xlr and have the tubes as you suggested. I also have other gear so I will fill all 6 sockets. I don't use the headphone section. Thank you
  • Joey_V
    Joey_V Posts: 7,672
    I have a total of 6 popes
    Now I need to hoard more for the future
    Joey's Gear:
    Current Gear:
    Primary:
    Secondary:
    Tertiary:
    Old Gear:
    Speakers:
    Source:
    Preamplification:
    Amplification:
    Subwoofer:
  • verb
    verb Posts: 9,925
    edited February 2020
    So a little drama on the Cary. I'm getting no output from the right channel on Aux1 and Aux3, both RCA connections. Did the typical troubleshooting, swapped cables, components, even swapped the tubes on the unbalanced circuits, to no avail.
    Aux2 works, which is also an RCA connection, which is weird to me, but that IMO ruled out bad tubes. The XLR outputs work fine.
    Cary provided a quick response to my email sent yesterday, unfortunately no other suggestions were offered, other than sending it in for service.
    So I'm thinking about getting the repairs done, and bundle it with the ultimate upgrade since it will already be there.
    Since I connected the Cambridge to the Northstar DAC, I really only need 1 RCA connection. And I can play with the XLR's as well. So it functions for now, but I'm leaning toward just sending it in. Get everything checked, fixed, upgraded, better than new.
    All I can say it is good to have a back up! :smile:
    Anything I miss? Any help, advice, or other troubleshooting suggestions are most welcome!
    treitz3 Posts: 14,558
    Unless you have a schematic and are comfortable working inside a unit at component level? Send it in for service.
    ~ I have found excellence ~
    ~ The best way to enjoy digital music reproduction is to never listen to good analogue reproduction ~
  • Joey_V
    Joey_V Posts: 7,672
    Get it upgraded and send it my way
    Joey's Gear:
    Current Gear:
    Primary:
    Secondary:
    Tertiary:
    Old Gear:
    Speakers:
    Source:
    Preamplification:
    Amplification:
    Subwoofer:
  • verb
    verb Posts: 9,925
    treitz3 wrote: »
    Thanks Tom. Time is really a big factor for me as well. So many other projects in line before that!
  • JayCee
    JayCee Posts: 1,237
    You were contemplating the ultimate upgrade several moons ago. Had you done it, you'd not be contemplating it, again. You know you want it. As the great Nike gods say..."Just do it".
    Speakers: Polk1.2tl's (Uber Mods) Pre/Amp/DAC: PS Audio BHK Signature & 250, DirectStream Cables/IC's: MIT S1Bi-Wire/S1 Balanced +Avel Lindberg 1000VA "Dreadnought" Power Conditioner: PS Audio P15 Power Plant Power Cords: Core Power Technologies Gold, DH Labs Power Plus DIY w/Neotech NC-P301 & P311ends Streamer: Roon ROCK on wifi'd NUC & Uptone EtherREGEN, AfterDark, Emperor Double Crown Clock, Black Modernize LPS⟿Ω☯☥☮⟿🔊♩♪♫♬♩♪♫♬♩♪♫♬
  • verb
    verb Posts: 9,925
    JayCee wrote: »
    Right you are sir! I'm a "if it ain't broke, don't fix it" kinda guy. Now it's broke! :smile:
  • verb
    verb Posts: 9,925
    Joey_V wrote: »
    Sure! Uh, no! :smile:
  • WagnerRC
    The pope tubes are very nice. If you can find any. Seems the supply is short right now.
  • Joey_V
    Joey_V Posts: 7,672
    My 6 popes ain’t leaving this house
    Joey's Gear:
    Current Gear:
    Primary:
    Secondary:
    Tertiary:
    Old Gear:
    Speakers:
    Source:
    Preamplification:
    Amplification:
    Subwoofer:
    audioluvr Posts: 3,628
    verb wrote: »
    Are you saying XLR's in aux 1&3 work but not RCA's?
    Cambridge Audio 851N Streamer/DAC
    Belles 350A Reference modded with Mundorf Supreme caps
    There is about a 5% genetic difference between apes and men …but that difference is the difference between throwing your own poo when you are annoyed …and Einstein, Shakespeare and Miss January.
    by Dr. Sardonicus
  • verb
    verb Posts: 9,925
    audioluvr wrote: »
    verb wrote: »
    Aux1 and Aux3 are RCA only. Aux2, which is also RCA, works fine. Both XLR1 and XLR2 are fine. From the web:
  • GlennDog
    That sux!
    JayCee is right, tho . . . You’ll love The Ultimate Upgrade
    Good luck, bro
    Mains Salk HT2-TL
    Center Salk HT2C
    Pre Cary SLP-05
    Wires WW & MIT
  • verb
    verb Posts: 9,925
    GlennDog wrote: »
    That sux!
    Good luck, bro
    Thanks Dog! Lot's of rave reviews on that upgrade. The rep from Cary stated that they have done over 1500 upgrades to date. And my turn around time would be about a week! Thinking, thinking, dang I think too much! :smile:
  • Joey_V
    Joey_V Posts: 7,672
    Stop thinking and do it
    Joey's Gear:
    Current Gear:
    Primary:
    Secondary:
    Tertiary:
    Old Gear:
    Speakers:
    Source:
    Preamplification:
    Amplification:
    Subwoofer:
    verb wrote: »
    And while it's away, you can upgrade the big boys...
    by Dr. Sardonicus
  • verb
    verb Posts: 9,925
    So today, I created an RMA for my beloved pre! While in for repairs, and the hood open, I've decided to go for the ultimate upgrade! Gonna get it packed up and shipped out hopefully this weekend! :smile:
  • JayCee
    JayCee Posts: 1,237
    Hip, hip, hooray! 'Bout damn time. Don't think I could handle another round of, "Wait, fixed it." Only to be followed up a couple of months later by, "Nope, hmmm, wonder if I should..."
  • verb
    verb Posts: 9,925
    JayCee wrote: »
    Yep! All the previously given good advice, now heeded! :smile:
  • JayCee
    JayCee Posts: 1,237
    I hope it's everything, and more than, you hope for!
    I made a decision of my own, today. Alluded to in another related thread... ;)
  • verb
    verb Posts: 9,925
    JayCee wrote: »
    Found it! Do it brother! :smile:
    verb wrote: »
    Sucker born every day!
    Takes one to know one. ;)
    by Dr. Sardonicus
